04-14-2012, 01:07 PM | #1 |
what filler neck fits here?
is this just a blazer filler neck that fits in here? what year truck can I get one off of?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
04-15-2012, 10:01 PM | #2 |
Re: what filler neck fits here?
Anyone know?
04-17-2012, 09:18 PM | #3 |
Looks similar to a 88-98 truck but slightly different. No finger lift hole and different shape cut out. I don't think a blazer fill would work since the cap sticks out of the side like the trucks and held in place with a rubber grommet but I don't own a blazer so I can't say for sure, unless they made that funny support behind it to hold the filler neck behind the door. Maybe you could remove that support piece and use a filler from an 88-98 truck. Or the 3 holes in the support look like it may line up to the filler tube from an 88-98 if you remove the plastic housing (see the two screws just under my cap, there is another on top that you can't see). The 88-98 filler door is 6" if that helps.
Anyone else have a clue?? Edit; 800mp pic wont load? will try later
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
