Old 04-14-2012, 05:15 PM   #1
frog210
74 chevy radio?
hey guys its me again
i have a question
the previous owner installed a pioneer radio or kenwood
(dont have pics at the moment or truck in front of me)
what i wanted to know is
isn't the radio suppose to keep its memory when the truck is turned off?
I looked at the wires briefly and noticed the previous owner just cut the factory radio harness off and wired the radio in
I noticed that the red wire, yellow wire and orange + and orange - were all wired together?
also how do i wire the antenna?
people been telling me these copper wires in the windshield are the antenna?
I noticed there is a metal tab on the inside where i guess the wires in the windshield connect to it, but how do i connect the radio antenna wire to it?
frog210 is offline   Reply With Quote
Old 04-14-2012, 06:31 PM   #2
Zane M
Re: 74 chevy radio?
The red wire off the radio should go to a switched power source(such as the original radio power wire). The yellow wire needs to go to a constant 12V source. It sounds like both are wired to a switched source, and that is why there is no memory retention in your case.
Check up under the dash about the same place the metal tab is. There should be a female antenna end that you can plug the radio antenna lead into. That is if someone hasn't butchered it.
Zane M is offline   Reply With Quote
Old 04-14-2012, 06:40 PM   #3
frog210
Re: 74 chevy radio?
could i run the yellow wire to like the cigaret lighter?
my lighter is always hot so i guess that could work
Ill check on the antenna plug later too
hopefully it aint butchered out like everything so far
Old 04-14-2012, 07:21 PM   #4
Square_78
Square_78's Avatar
Re: 74 chevy radio?
Just run the yellow wire to the fuse box to a constant powered terminal. Be sure that the yellow wire has a fuse on it.
Square_78 is offline   Reply With Quote
Old 04-14-2012, 08:48 PM   #5
bilfman
bilfman's Avatar
Re: 74 chevy radio?
You could run to the cig lighter if you want. But most fuse boxes will have some constant power tabs to hit.
You dont need to use the power antenna wire (unless you have a power antenna that goes up and down) this lead is to activate power antennas on a power antenna equipped vehicle. So if you dont have an actual power antenna just tape or cap it off because it will be 12v live when your deck is turned on.
Your antenna to the deck is the bigger round plug, kinda like a mini plug that you would put into a cigarette lighter. There is only one place to put that in the deck. The deck is the female side.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-16-2012, 11:23 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 74 chevy radio?
yes the constant power can go to the lighter
I also run the main power threw that, with a switch
my switch runs up without key,middle is off,down is with key
been doing this for years no issues
now wired the same using the Pioneer
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-16-2012, 11:31 PM   #7
frog210
Re: 74 chevy radio?
I ran my constant power from the connection on the fuse block,
It had two wires one going to the clock, and another one wire to add something
I just ran the wire with a fuse to the yellow radio wire
It worked perfectly
Ran a copper wire to the antenna in the windshield to the radio antenna wire
It's just temporary for now
