04-14-2012, 07:02 PM | #1 |
Little help just have a few questions
Hey guys, picking up new truck, while its not my first Chevy it is the first 4x4 chev ive had. 79 k10 w/ 4" sus lift and 3" body. (body coming out of it). 4 brand new 35" rubber decent running 350 but Trans issue. No rust anywhere. $800 bucks!
Anyways my dumb question is what is the difference in tcase positions? I've never seen lo, lo loc, n, hi, hi loc. before. Posted via Mobile Device |
04-14-2012, 07:17 PM | #2 |
Re: Little help just have a few questions
That's the full time 4wd version..... It's a New Process 203 transfer case....
There is a 3rd differential in the T-Case, the LOC position locks it for absolute true 4wd making both driveshafts spin at the same speed. One of the biggest misconceptions is that this is a week T-case. Not so..... Had one in a 79 GMC K25 and did lots of plowing in MA with it. Worked great. Common for many folks to convert these to part time by either installing a kit in the t-case or manual hubs up front. Stick with "HI" for normal driving, "LO" for low range 4wd and "LO LOC" for low range locked front and rear or "HI LOC" for high range locked. Either way, you have 4wd all the time. Hope this helps. Sounds like you got a good deal! Last edited by beamn7; 04-14-2012 at 07:26 PM. |
04-14-2012, 07:19 PM | #3 |
I knew it was a np203, just not familiar with the positions.
04-14-2012, 07:54 PM | #4 |
The low and hi of the 203 function basically like an 'open differential' function. The T case allows slippage between the front and rear diff, kind of the way spider gears work in an open diff, this just helps with drivetrain strain because these were fulltime units, really helped with stress when operating on dry pavement. Hi loc and low loc make the case function like the 205 and such. When in the 'loc' the t case does not allow any slippage between the front and rear diff, just functions like most other cases.
That said the 203 is as tough as a 205, the case weighs about 360 lbs and the chain is twice the size of a 208. Many peeps convert to locking hubs and will put in a part time kit, the part time kits is basically a modified shaft for the rear of the case. The problem with this mod and many find out the hard way. Is that the 203 is meant to be spun to oil the top of the case. A part time mod does not allow the case to spin and oil. There are 2 ways to assist this. Run the unit in 4wd either engage the shifter or the hubs about every 200 miles for about 10 minutes. Or as I am trying now (but I've been assured it works) put an extend the filler plug 2 inches higher with some 1/2 pipe, this lets you fill the case 2 inches higher and will oil the top end. Remember this case is oiled with a max 30 weight oil. DO NOT use gear oil. I have used a 10/40 for years with no problems, but being from Canada the lower viscosity helps in winter.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
04-14-2012, 08:20 PM | #5 |
Thanks that explains it. Feelin dumb now haha.
Will have to get some pics up of the new truck. Once it's ready to roll it will be replacing my 92 f150. Posted via Mobile Device |
04-14-2012, 08:32 PM | #6 |
Hey no problem!!! When I got my first 203 I had the same questions.
