Old 04-14-2012, 08:15 PM   #1
cfan10
cfan10's Avatar
Cool Steering wheel vibration
I had the steering wheel tightened because it was very loose, you could really shake the wheel.
The shop did this and they claim to have found that the steering wheel bearing was shot, it was replaced.
Long story short, I have serious vibration when driving at highway speeds 60-75mph also sometimes I hear like a squeaking noise when steering wheel shakes.
Also, has anyone heard of straightening tie rods ends?
They also did this, is it safe?
Any advice on this is greatly appreciated.
cfan10 is offline   Reply With Quote
Old 04-14-2012, 08:31 PM   #2
bilfman
bilfman's Avatar
Re: Steering wheel vibration
Can you drive through the vibration?? ie it vibrates from 60-70 then stops? This usually means a drive train problem. Driveshaft or ujoint. Otherwise I would suspect a bad tire or unbalanced wheels.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-14-2012, 08:45 PM   #3
cfan10
cfan10's Avatar
It pretty much vibrates then stops, and I had the ujoints changed, because the shop owner said they were bad. I was told on here I believe, after posting pics that all the clips weren't put on the ujoints. Thanks.
Old 04-14-2012, 10:20 PM   #4
oldschool18
oldschool18's Avatar
I was taught if it shakes in the steering wheel its in the front end if you feel it under your butt its in the rear unless its a real bad problem then you feel it everywhere
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 04-15-2012, 10:28 AM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
Yes, steering wheel vibration is almost always something to do with the front end. As far as straightening tie rod ends, I'd never go back to that shop, not even with my bicycle. If tie rods are bent you replace them, period.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
