Need help asap!!!
I just finished putting on my new carbourator on my 75 gmc, but I now have a HUGE problem!! when I crank the truck over, just before it catches the carb backfires, then stays on fire for a few seconds! We reacted quickly and put the fire out with water.. no one was hurt thankfully, but could it mabey be the vacuum lines? my timing, or fouled plugs?
Re: Need help asap!!!
Did you mess with the distributor or timing?
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
If you pulled the distributor it looks like it might be turned 180 degrees.
If you moved it towards the pass side the timing will be retarded. This is an easy fix, if you know timing. If not there is a lot to explain. Try turning it back towards the drivers side and see if it will start. Don't turn it over forever, if it doesn't start keep going back until it does. If it doesnt, there is more work to do.........
Don't ever throw water on a gas fire.
It can spread the gas and cause a big fire. Posted via Mobile Device
That big vacuum fitting,under the fuel inlet,at the front of the carb should have a hose to connect it to the PCV valve,also,or you'll lose engine vacuum.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
I fixed where the vacuum hose goes, Truck was running beautiful... for 15 minutes..
