Old 04-14-2012, 09:25 PM   #1
HotRodScottsdale
HotRodScottsdale's Avatar
Squeeking when moving
I get a high pitched Squeeking when I'm driving but if I put a bit of pressure on the brake peddle it stops, not enough pressure to engage the brakes or the lights but just enough to stop that sound, any hints?
HotRodScottsdale is offline   Reply With Quote
Old 04-14-2012, 09:28 PM   #2
joe231
joe231's Avatar
Re: Squeeking when moving
Your front pads are low.
What you are hearing is the wear indicator contacting the rotor.
They are designed to "sing" while there is no brake pressure and when you apply break pressure they stop squealing.
CHEVY ONLY
Old 04-14-2012, 10:49 PM   #3
bilfman
bilfman's Avatar
x2 Yup time to change the front pads. The squeelers are built into the pads to warn you "hey mofo I needs a changin", they do this to annoy you into doing it before you wear your pads down to nothing and do serious damage the rotor.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-15-2012, 01:19 AM   #4
cory d
cory d's Avatar
i have what you are describing. i beleave its my vacuum line to my brake booster, it also changed with rpm
cory d is offline   Reply With Quote
Old 04-15-2012, 12:40 PM   #5
HotRodScottsdale
Both of those sound possible, I haven't touched my brake pads ever but the brake booster did get replaced with a used one, I'll check my pads then the line
Old 04-15-2012, 12:53 PM   #6
joe231
joe231's Avatar
http://auto.howstuffworks.com/auto-p...isc-brake4.htm
CHEVY ONLY
