70 chevy A/C ?'s
So I am getting ready to get the a/c going and realized that the recirculated air comes from the vent inside the cabin. Almost the entire vent system has no insulation whatsoever. It looks as if the air would get heated from the outside heat beating on the sheet metal. Any one notice this? I was thinking of insulating this area and possibly making an air cabin type filter for this vent. Any ideas?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Re: 70 chevy A/C Upgrading.
OK.. Sooo I've come up with a radical idea. (I am nuts) I am going to close off the cowl to "fresh" air. I am sick of leaves and trash rotting in there and getting into my evaporator and heater core.(as well as rusting out my truck) I am going to drill out the sheet metal right in front of the fan squirrel cage and go straight thru to the cabin. I should be able to duct this easily and install a round engine type filter. The kind used for fuel injection rice burners. I will the use the vents for some speakers. If I need fresh air I will just open a window. THOUGHTS????
This should eliminate the heating of the duct from the outside air. I realize the outside air will not be able to enter my cab except through a window but I never use that option anyway. I am thinking some removable aluminum plates over the holes in the cowl so I could still work on the wipers if necessary. ![]() |
Re: 70 chevy A/C ?'s
Did I do something wrong or does any one know what I am talking about? Maybe I need to post a pic. The part I want to cut out is just inside the hole for the fan.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 04-18-2012 at 07:02 AM. Reason: going advanced |
Bumping this thread cuz I am going to get to cutting this thing out soon if there are no objections..Someone say don't do it ?? I may end up with the best a/c ever..or make a big mistake.
I too have thought about stuff like this. I was thinking of eliminating the outside vent and removing the door off of the inside kick panel. Another suggestion I got on here was to put some radiant barrier on the evaporator core box to keep radiant heat from the engine away.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#6 | |
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Why not just block the cowl flapper closed, and the kick panel vent open? No need to modify anything else.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Moderator
![]() Join Date: May 2007
Agree.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
This is because the air would still have to go through the engine-heated cowl section behind the fender through the vent system. If I go straight through to the cabin by opening up the sheet-metal in front of the squirrel cage It would eliminate that heating of the air.
#10 | |
Think I'm gonna do it! Tell you how it goes when I get it Blowing. I think the lack of resistance should work well too as well as keeping junk out of the evaporator. Might put a k-n filter in later but will try this for now.
#12 | |
Moderator
#13 |
Trying not to mess up a good theory with bothersome facts. But... If you are using recirculation all the time it is inviting rust and moisture collection. Use recirc. to pre-cool then shift it over to nomal for best overal A/C performance. Keeping the evaporator clean and draining are the best improvements you could do. A thermal barrier from engine heat on the outside of the case and the engine side of the firewall and cab floor may help but not necessarily cost effective. Worring about convection from the sheetmetal is pretty far down on the list though, but white roofs do help. Your glass area is the biggest problem overall. You would be amazed seeing an A/C thermal preformance map. If you move the air through the system too fast it will not cool as nearly much. Many GM vehicles actually cool better on a medium vs a high fan setting for this very reason.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#14 | |
#15 |
Old member
I can't see the sheet metal warming the air back up once it is cooled down. That is the whole idea behind AC systems. Once the truck is working and it's cooled off it should stay close to that temp if the system is operating like it should.
I blocked off the cowl vent last summer on mine and leave the passenger side vent open and it runs 35-40 degree's no matter what the outside temp is. Yes insulating would help some also and having the AC blow straight through to the cab may work fine. I can only see the noise level going up though because of the fan being straight to the cab plus the engine noise may be more. The only thing to do is try it and see! Good luck and post what you find. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#16 |
Doing it this week and will let you know. Any one got a good way of cutting that sheet metal? I usually drill a series of small holes and then use a high speed cutting tool with a drill bit that has teeth on the side for elongating holes to cut through what's left and then de-burr with a rotary type file of sorts but it's a lot of work.
#17 |
A high speed air reciprocating saw works great.
#18 |
I don't have one of those saws so here we go old school. Doing it tomorrow I thinks. I just have to get that beast on the road. Are you with me?
#19 | |
It'll Buff Out!
![]() Join Date: Apr 2007
Your home A/C is only a direct recirculation system because in theory you will introduce fresh air into the home through doors opening and closing, etc. In a commercial application you need to maintain a 15% fresh air introduction I have not seen a new vehicle yet that has eliminated the fresh air introduction. We had problems with our 2006 sequoia after a road trip from CA to south FL and back. The system was set from the factory for max a/c (recirculation) every time it was turned on. The evap never dried out because of the lack of fresh air the system mildewed. We fought them and had them replace it under warranty because there was no ozone safe, enviro friendly flush here in CA. (there was in Florida, the dealer offered it but we didn't have a problem till we got back.) As far as new home systems go, you have to remember, better insulation, dual pane windows, and more energy efficient systems (do to lighter thinner metals in equipment construction) are what help your house. When it reaches set point it shuts off. Put that same system in a 1970's house and it will run just as long. I have 3 machine at work side by side, 1 Trane energy efficient variable speed, variable drive chiller that uses new gas, lighter metals etc. and 2 1967 carrier Cast iron r-11 (not r-12) 4160 voltage tanks. Energy efficient… not a chance, cooling efficiency… Those carriers will cool twice as fast as that Trane, then idle down and bake the seals out of themselves because they want a heat load to work with and 40 years of remodeling, and upgrading has removed it. Don't knock old tech. Tint your windows and insulate your cab would be my recommendation. In the end it's your truck and you can do with it as you want. I do really hope it does what you want. I just hate to see you cause yourself a problem in another area because of it. Let us know how it works.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
#20 | |
#21 |
The main idea for this is to not use the cowl for air and to close it off. My Blazer has sustained severe rust from the Florida leaves and rain getting in there and every time you get on the road leaves and trash blow into your eyes and it can be somewhat dangerous. There has to be a better way. I would like to shave the entire cowl as well. I saw it done on here not too long ago.
#22 | |
Oh and I did cut that hole in the firewall. Raining like he!! right now so I will post some pics later.
