Old 04-15-2012, 08:41 AM   #1
gysgtc
Serpintine belt system lower hose
All I can find about a part number for the lower radiator hose is a Gates 20842. But the info on it says the one end is 1 1/2 " I need 1 3/4" on both end. I tried an auto zone 70664 but it is too short at the water pump end. 67 c10 350. Anyone have a good p/n? Thanks
gysgtc is offline   Reply With Quote
Old 04-15-2012, 10:14 AM   #2
Lee H
Lee H's Avatar
Re: Serpintine belt system lower hose
Not sure this will help but I have the GM serp system on my 72 and I use the stock hose.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 04-15-2012, 11:40 AM   #3
gysgtc
The only one they show for a 72 that has 1 3/4" ends is only 12 3/4" long and that is way to short I think. PN D71337 autozone
Old 04-15-2012, 11:52 AM   #4
Lee H
Lee H's Avatar
From O'Reilly's
Gates - Radiator Hose
Part Number: 20694
Line: GAT
1 year limited warranty
• UPC: 72053052442
• Centerline Length (in): 23.2
• Centerline Length (mm): 589
• Number of Branches: 0
• Inside Dia. 1 (in): 1.75
• Inside Dia. 1 (mm): 44
•Lower
•Cut To Fit
This ois the one I use. HAve to cut off about 3 inches or so.
Old 04-15-2012, 11:59 AM   #5
Lee H
Lee H's Avatar
Look at this from Auto Zone, Dayco Part Number: E70664
This is the part that comes up when I put in my trucks data.
Old 04-15-2012, 12:08 PM   #6
Legolas894
Chemist under the hood...
Legolas894's Avatar
If you have the right length and it's only the size at the end you can buy a sleeve that fits over the rad fitting and enlarges to the right size. I did that so that my newer rad fits my existing hosing. NAPA has these, Good year makes them too.
http://www.goodyearep.com/productsdetail.aspx?id=15008
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 04-15-2012, 01:17 PM   #7
mkmc69
mkmc69's Avatar
If you are running a serpentine set-up, you should be using a reverse rotation water pump, so wouldn't it already be the correct size, or am I thinking wrong?
mkmc69 is offline   Reply With Quote
Old 04-15-2012, 01:46 PM   #8
gysgtc
I ended up with a E70664 from auto zone. The end that goes on the water pump didn't drop down far enough before the bend so used short piece of exhaust pipe with a short piece of hose on it and then put the E70664 hose on it. The end that goes on the radiator was too long so cut it and that is the piece that went on the water pump.
Old 04-15-2012, 01:47 PM   #9
terry b
terry b's Avatar
If you go cross country with a setup like that and say you need a new idler pullie or alt mid trip. Can you find part's for it? Or would you have to order them.
terry b is offline   Reply With Quote
Old 04-15-2012, 02:03 PM   #10
Lee H
Lee H's Avatar
Glad it worked out, I think that belt is on the wrong side of the idler, at least mine is on the other side and is correct for my application.
As for serpentine related parts (idlers, alt, PS pump, water pump, Clutch fan, AC compressor, etc) one would order or buy parts for the model the serpentine was removed from, in my case 1992 C/K 1500.
Old 04-15-2012, 02:05 PM   #11
gysgtc
Are you referring to the serpintine setup or the hose setup. Besides that, at the price of gas it won't be going on any long trips.
Old 04-15-2012, 02:13 PM   #12
gysgtc
The belt is on the right side for this setup. Here is the one I have on the engine.
http://www.jegs.com/i/GM%20Performan...0002/-1?CT=999
