Old 04-15-2012, 02:27 PM   #1
Super73
Super73's Avatar
Motor/frame mounts
Ok, searchin LMC and can't find the metal piece that the motor mount bolts to. We are going to be doing a 60 panel 5.3 swap, have the adapter plates but now need a set of V8 Frame perches (if that's what they are called).
Anyone seen them in LMC or have a better name for them? Most our local pick your parts don't have the V8 trucks. Or will a later one work? We are putting a later disk brake front clip in the truck too.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-15-2012, 08:31 PM   #2
68Stepbed
68Stepbed's Avatar
Re: Motor/frame mounts
I have a set each of stock 6-cyl, and V8 perches if you need them. $20 per pair plus the ride.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
