Fabricate till you "puke"
2000 GMC G80 rear diff
What do you guys run for lube/traction addative? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: 2000 GMC G80 rear diff
Most of the big name synthetics already have Posi additive.
Synthetic 75W-90 is the grade spec. Mobil 1, Amsoil, Royal Purple.....Cant go wrong with any of these. |
A big thanks
