04-15-2012, 06:31 PM | #1 |
do I have 1/2t or 3/4t?
I was told by the PO that my 79 blazer was a 3/4 ton now, that someone had swapped it all out. I wasn't really concerned about it at the time, but now I am curious to know what I have in there.
What would I be looking for to tell between the two setups? I have 6 lugs 3 leaves up front, 6 leaves in back looks to be a Dana 44 in the front I think a corporate 10 bolt in the rear. What else would be an indicator? Here is what I have up front: and in back:
79 Blazer 350 TH350 part time 4wd Sold! 86 GMC 1 ton something... |
04-15-2012, 06:37 PM | #2 |
Re: do I have 1/2t or 3/4t?
6 lug = 1/2 ton (all Blazers were 1/2 ton originally)
8 lug = 3/4 ton unless he did some trickery with the axle shafts. Judging from the photos I'd say 1/2 ton. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-15-2012, 06:52 PM | #3 |
Cool. That's what I was leaning towards believing.
Thanks.
04-15-2012, 07:15 PM | #4 |
It's a 1/2 ton unless you posted or took the wrong pictures.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
04-15-2012, 07:18 PM | #5 |
Nope. those are the right ones. Thanks.
04-15-2012, 07:20 PM | #6 |
Rear is a 12 bolt
~Jon Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=516056 |
04-15-2012, 07:20 PM | #7 |
You know it wouldn't hurt to see more pictures of the truck...
04-15-2012, 07:22 PM | #8 |
Canadian Trucker
You have a 1/2 ton, you've got a 10 bolt front and 12 bolt rear.
2020 Silverado Trail Boss - 6.2/10spd |
04-15-2012, 07:33 PM | #9 | |
More here too.... http://67-72chevytrucks.com/vboard/s...d.php?t=517186
04-15-2012, 07:35 PM | #10 |
Nice Blazer, my mom has always wanted a fullsize Blazer.
04-15-2012, 08:45 PM | #11 |
The CUCV m1009's were 3/4 ton capacity but still has 6 lug axles...
So I guess just swapping spring could get you a 3/4 ton capacity. My K20 Burb has 3 front springs, I'd have to check the rear springs. Posted via Mobile Device
CHEVY ONLY |
04-15-2012, 09:05 PM | #12 | |
Canadian Trucker
At best they were a 1/3ton truck. They don't have the brakes or frame for being considered 3/4 tons. Most trucks had three springs, but I believe the thickness was different in each weight class.
04-15-2012, 09:17 PM | #13 |
Was 6 springs standard in the rears too?
04-15-2012, 09:21 PM | #14 | |
1 1/4 ton. The M1009's were stripped down though, so that may have helped with the capacity I agree that they weren't a typical 3/4 ton, but I'm also pretty sure the government had them hauling and pulling in excess of the 1/2 and possibly the 3/4 ton capacity. And btw, 1/3 is less that 1/2 Posted via Mobile Device
CHEVY ONLY |
04-15-2012, 10:04 PM | #15 |
Canadian Trucker
Yea, I meant 2/3 ton, big fingers small key board
M1009's were rated as 1200lbs payload and 3000lbs towing capacity, and 1/2 ton trucks are rated at 980 - 2680lbs payload and 4500-6200lbs towing capacity. They may have called them 3/4 tons but they real weren't.
04-15-2012, 10:08 PM | #16 |
That's the government for ya...
They do what they please Posted via Mobile Device
CHEVY ONLY |
04-15-2012, 10:09 PM | #17 |
Canadian Trucker
I think so, my buddy's has 7 but I think I remember him saying he put in an extra leaf for towing.
04-15-2012, 10:11 PM | #18 |
Good to know.
I am still trying to figure out exactly what I have here. No sticker in my glovebox to help.
04-15-2012, 10:14 PM | #19 |
Canadian Trucker
Take your vin the your local GM dealer and ask the parts department for your trucks option print out. If they are in the least bit good people they will do it.
04-15-2012, 10:16 PM | #20 |
Awesome! I will definitely do that.
04-18-2012, 01:33 PM | #21 | |||
It may have 3/4 ton springs, but I doubt it; does it ride absolutely horrible, then they might just be 3/4 ton springs? If you swap out the innards/spindles/etc on the 10 bolt front from 6 to 8-lug, you have a LD 3/4 front. I am not aware that the same can be done on the rear, but since it is a 12-bolt, maybe it can with the proper (8-lug) axles? Quote:
Never owned either (only 1/2 ton trucks) so I could be wrong, but that is what I have been told. With all that said, I have recently bought an '85 4x4 3/4 ton Suburban which I believe to be a trailering special, or some other HD version; it has a T400, 4.10's and was not eqipped with a catalytic converter from the factory. The front axle looks nothing like the 10-bolt in my '89 Jimmy (K5)? And the frame looks very tall? So I would belive that their could be two versions of a truck frame; a LD version (like a 1/2 ton with higher capacity springs/rear-axle) and a HD version (more like a 1-ton with lower capacity springs/axles(plural)). YMMV. Which might be moot since a K5 is a 1/2 ton...
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
04-18-2012, 01:37 PM | #22 |
I am pretty well convinced I have a 1/2T now. I was before as well, but I figured I should check to be sure.
04-18-2012, 02:51 PM | #23 | |
Canadian Trucker
If you look at your suburbans front axle, from the front of the truck. In the lower right of the diff, on one of the gussets, there will either be nothing written there, or a 60 or a 44. If it says nothing is a 10 bolt, if it says 44, then its a dana 44, and if it says 60, then its a dana 60. I'm betting its a 10 bolt or dana 60, since the 44 was replaced in 80 or 81. There never was a 3/4 ton blazer frame made, the reason most call the cucv a 3/4 ton is because it can do more then the civilian k5. But in honesty, it's still no better then a 1/2 ton truck. The cucv was a base model k5 with heavier duty spring (probably 3/4tons springs), a 6.2 diesel, and th400 trans. The axles are the same from the civilian k5 (both were 10bolts), and I believe all were equipped with 3.08's and a g80 rear.
05-04-2012, 09:59 PM | #24 |
If CUCV Blazers are 3/4t then my '85 Jimmy is a 1t . Nah,mine is a diesel and has '91 Suburban 3/4t axles,but I consider it a 1/2t sonce it has lift springs that are the same for 1/2 and 3/4. Because it's a base model (Sierra) in solid Doeskin Tan w/Buckskin interior,dull paint,and black wheels I have guys ask if it's military. My standard answer is,"No,it's better"
