04-16-2012, 11:28 AM | #1 |
Static Drop Questions
I have been searching high and low and cannot figure out a direct answer. I have a few questions. I have a 70 SWB truck and want to lower it.
In the summer Im always pulling a trailer and do not want to bottom out. I want it the lowest I can go, without bottoming out. I was thinking a 3/4 drop or 4/5 drop. Id even do a 2/3 drop if I had to. Which one would be the best route to go since I will be towing? What all would be needed for a 3/4 drop, 2/3, and 4/5 drop. I keep reading people are c-nothing at 5 and 6" drops in the rear and that is not something I want to do at this point. Do the shocks really need the relocation brackets and an adjustable panhard bar? What is the lowest I should go with just ordering a spring in front instead of a drop spindle? Most likely it will have 20" wheels but the 18" are not out of the question. Any pictures would help greatly. Thanks. |
04-16-2012, 12:15 PM | #2 |
67-72 parts collector,…
Re: Static Drop Questions
3/5 drop is the lowest spring drop.
This will require drop shocks, rear shock relocator and adjustable track bar. (no notch). A 3/4 drop would require: 1) drop shocks up front. 2) Stock rear shocks and brackets. 3) Stock track bar. A 2/4 drop would let you use stock front shocks. Just remember,... these drop springs are "x" inches lower than new replacement stock springs,... NOT your sagging 40+ year old springs that are on the truck now. So a 2" drop spring might only net you 1" of additional drop.
04-16-2012, 10:08 PM | #3 |
ok so with the 3/5 drop, that will even the truck out correct? Just asking because so many trucks on here have a 2 inch more drop in the rear and still have a small rake. Might be their wheel configurations.
Would I still be able to tow with a 5" drop in the rear? will I need to take the rubber frame bumpers off? Thanks |
04-19-2012, 04:06 AM | #4 |
Old member
I cut my rear rubber even with the frame so it just hits the rubber before the frame. Then I added the helper air bags and it works great. The ride is outstanding.
04-19-2012, 09:39 AM | #5 |
Alright thanks, What drop do you have on your truck? Do you know how much travel room in the rear you have?
04-19-2012, 02:23 PM | #6 |
Old member
Check this out. This is a video of my truck running 20" wheels all around.
With the shock relocator and helper air bags.
04-19-2012, 02:50 PM | #7 |
alright im convinced. guess if its not stiff enough ill throw some helper bags on it as well.
