Steering wheel is shaking at high speeds, but I didn't want to replace bushings, ball joints, tie rod ends and sleeves. Until I moved to dallas.
But I am doing an oil change, tune up, changing belts, tires, coolent, hoses, p/s pump, fan clutch, thermostat, oil pan gasket, waterpump gaskets, thermostat gasket, exhaust manifold gaskets. New interstate battery. Possily waterpump. Is there anything I'm missing here. Transmission also needs front seals, so it has a slight leak, thinking I'll just top it off for the drive. But it will be taken care of in dallas. Ujoint replaced, trans gasket, filter. Posted via Mobile Device |
Re: Trip from houston to dallas, one way...what to check replace
Leaking front Trans seal = broke down. Done it twice I won't let another bad front seal claim another of my transmissions.
78K & 79C Jimmys
figure out your route,post it, members might be able to help if bigger stuff comes up
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
That is an awesome idea. That is what makes this forum the best out there. everyone is willing to help at a moments notice.
^^who I am^^ what I say>
Replace water pump and flush the radiator good. check all the tires, check the rear end fluid, repack front wheel bearings, spare tire, basic tool kit, extra fluids, snacks, beer, etc.
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
#6 | |
I'd check my speed on the trip. Loose front ends concern me. Take it easy.
BAD BOW-Silverado XST
I'm in Austin.
as long as it's been properly maintain she will make it. DON'T FORGET YOUR BRAKES! I forgot to check them on a 1400mile trip ended up shattering the shoes and creating much more of a problem. other than that a maintained truck will do well
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e Last edited by Goldfinger; 04-17-2012 at 08:41 PM. |
