Old 04-16-2012, 05:49 PM   #1
BrookelynnGreen
BrookelynnGreen's Avatar
power steering squeels
So I replaced my power steering gear box and power steering pump 3 months ago and everything was working 100% OK. Well I got stuck in a ditch during a tornado and had to have someone push me out, and somehow the belt came off my power steering pump as he was pushing my truck and I was turning to get unstuck. After our area was cleared of the weather threat we went outside to examine the power steering. He reconnected to belt and everything went good, I go on my way home. But now... When I put my truck in drive and turn it squeaks a bit, never did that before... While I'm driving and make a turn it doesn't squeak. What could be the problem?? Could the belt not be tight enough?? When I replaced the power steering components I made sure the belt was on tight. When he put the belt back on he didn't tighten it up the way I did. Could something be damaged? I checked the fluid and it good. I'm thinking I need to tighten the belt up the way I had, just thought I get your guys's opinion.
Thank You
-Samuel
"Knowledge Is Power"
BrookelynnGreen is offline   Reply With Quote
Old 04-16-2012, 06:11 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: power steering squeels
Once the belt "tosses" it is done. You can reuse it but it will either toss again or squeals, etc... Id buy a new one. I tossed a few when my alt was out a tad and if you lay it on the bench you can see its not flat anymore, got a twist in it...
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
