Old 04-16-2012, 11:13 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
What's involved in changing the dash?
My '69 C/20 dash looks like Swiss cheese (and I hate Swiss cheese anyway). It has so many holes in from the PO that I just don't know what to do. How hard is it to replace the dash? I am planning to add a Vintage Air system and it doesn't make sense to even do it to this dash. I'm wondering how I can repair or replace my dash. I know someone out there has done this before. I would appreciate any help.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 04-17-2012, 01:18 AM   #2
YBNORML
YBNORML's Avatar
Re: What's involved in changing the dash?
I am in the process of doing this exact thing. So far I have removed an unmolested dash from my parts truck.
Here is how I did it : Remove windshield
Remove everything attached to the dash itself
Drop the column and e-brake (67-68 only)
Drill out spotwelds, , mine had about 30 they are located at the front of the dash where it meets the windshield.
There are 3 bolts on either side where the dash meets the a-pillar.
It should pop out.
That is as far as I have gotten so far. Here are a few pics of my removal The roof removal was just for fun I'm sure some others will chime in.
Depending on the severity if the damage to your dash there are other options. If it is only the center of the dash, you could cut a center section out of a good dash and weld it in. I have a dash section out in the shop, I will take some pics tomorrow so you can see what I mean.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-17-2012, 08:17 AM   #3
derotoreut
derotoreut's Avatar
It should pop out.
Thanks a lot. This is great stuff. How do you get access to the bolts where the dash meets the pillar? Can you reach them under the dash, or do you have to remove fenders or something?
My dash has holes on both the left and right ends (where vents would be for an A/C dash). It also has the center section butchered up to. It also has holes there and the radio was cut. I don't think a patch fix would work in a case like this. I included pictures of a portion of the center section and the left side of the dash. The right end of the dash is basically the same as the left.
~ Dan
Old 04-17-2012, 10:44 AM   #4
YBNORML
YBNORML's Avatar
The bolts are accessible from underneath the dash. They are really easy to see and remove once the rest of the stuff is out of the way.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-17-2012, 01:00 PM   #5
mrein3
mrein3's Avatar
Look at YBNORML's last two photos. Lots of guys just take the dash pad off and slice at the slots hidden under the pad. The procedure that way is [leave windshield in] remove everything from the dash, cut at the slots, unbolt, cut donor at slots, unbolt it then bolt it in your truck. Then you just weld along the slots and cover the carnage up with your dash pad. You don't even have to tell anybody you did the surgery. You can also paint the donor to match while it is outside the truck and laying flat. Just tape up where you are going to weld and hit that bare metal with weld-through primer.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-17-2012, 01:15 PM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
^^ What mrein3 said
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 04-17-2012, 02:58 PM   #7
70-Chevy
-Chris
70-Chevy's Avatar
Replacing the dash was very simple when I did mine. I took the windshield out, drilled the rivets, unbolted the dash from underneath and it came right out. The new one went in just as easy.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 04-17-2012, 08:06 PM   #8
YBNORML
YBNORML's Avatar
I never thought of doing it this way, learn something new everyday on this site
Here is a pic of the center section like I mentioned in my first post. However, if I was to cut and change parts of a dash I think I would do what mrein3 suggested above.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-17-2012, 09:27 PM   #9
old Chevy guy
old Chevy guy's Avatar
What the heck did the PO have in all those holes?
old Chevy guy is offline   Reply With Quote
Old 04-17-2012, 10:23 PM   #10
derotoreut
derotoreut's Avatar
Like I said Swiss cheese right. I have now clue why there would be so many holes. How could you possibly use all those? :sum: I just want to figure out how to repair it right.
~ Dan
Old 04-17-2012, 10:46 PM   #11
YBNORML
YBNORML's Avatar
I must've been really tired when I got home from work. Here is the pic I meant to post earlier.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-17-2012, 11:10 PM   #12
derotoreut
derotoreut's Avatar
If just the center section was the culprit that would be a good fix. Mine however has holes on the left and right ends as well as the center section. I have no idea what the PO did with all these holes.
I need to replace the windshield rubber anyway, so that might be a good time to do this. Unless I do like Mrein3 mentions. Good thing I have a son-in-law who is an excellent body man.
~ Dan
Old 07-28-2012, 10:58 AM   #13
derotoreut
derotoreut's Avatar
Just an update on my dash. I got it all done. I installed a Vintage Air Kit and found an unmolested factory A/C dash from a Member on this site.
Instead of drilling out all the pinch welds we cut the old dash with a small wheel, and then did some disc grinding at the pinch weld area. With the replacement dash installed, it left the new dash a bit thicker at the site of the old pinch welds, but it was no problem at all.
The new dash was NOT welded in, but installed using the latest high strength liquid epoxy weld. I was a little nervous with this, but my son-in-law is an excellent body man, and he highly recommended it. This way it was also possible to paint the dash prior to installing it without worrying about damaging the paint by welding it in. The windshield is now installed and fits great with a new Precision rubber. Now on to bigger and better projects!
The 1st picture is of the old dash.
2nd and 3rd are pics of the new dash install
4th pic is with windshield back in
~ Dan
Old 07-28-2012, 03:13 PM   #14
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
