04-17-2012, 04:48 PM | #1 |
freon removal
Is it true that only R12 needs to be, by law, to be evacuated and the 134a does not? I am replacing compressor and was wondering?
If not will a shop evacuate a system?
Chief mechanic for my, 54 Belair, 64 Corvair, 72 C/10Fleetside and 2002Tahoe. John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me. My Book "Why Cancer is Not Bad Luck" by WestBow press |
04-17-2012, 07:49 PM | #2 |
Re: freon removal
The good ole EPA says NO. But alot of people do it anyway. A shop will be glad to take your freon, Charge you, The resell it to someone else! Talk about a profit margin.
Section 608 of the Clean Air Act prohibits releasing CFC-12 into the atmosphere. The prohibition on venting CFC-12 has been in effect since 1992. Section 608 of the Clean Air Act prohibits releasing HFC-134a into the atmosphere. The prohibition on venting HFC-134a has been in effect since November 1995. Can I vent HFC-134a or other refrigerant substitutes? No. Effective November 15, 1995, section 608 of the Clean Air Act prohibits individuals from knowingly venting substitutes for CFC and HCFC refrigerants during the maintenance, service, repair and disposal of air-conditioning and refrigeration equipment. A fact sheet explains this prohibition in much more detail. Note: although this prohibition is part of Section 608 (stationary refrigeration and air conditioning equipment), it also applies to Section 609 (motor vehicle air conditioning). |
04-17-2012, 08:04 PM | #3 |
Re: freon removal
Thanks!
Found a shop that will evacuate my system for $30 so I guess I will do that and have it done. Can anyone tell how many cans of Freon to put back in system? I know there is a label under hood but it will speak in pounds and I am going to use the cans of Freon from auto parts with one dye can or mixture.
04-17-2012, 08:08 PM | #4 |
Re: freon removal
i hate to say it but but it is easlier to let a shop charge it back up after the system is open it need a 45 mins min vaccum time i like to do 60 at my shop and then the machince can charge it to the excat charge lvl recommended by gm
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-18-2012, 04:57 PM | #5 |
Re: freon removal
I replaced everything today after having the system evacuated. Have a question; the only thing left is the orifice tube. The old one came out in pieces it was so tight. The new one is tight also is there an easy way to get the new one in? Do I have to drive it in and is that alright?
How have some of you put in a tight orifice tube? I will draw a vacuum after I get the orifice tube in and charge it up.
04-18-2012, 05:33 PM | #6 |
Re: freon removal
yeah the tube can be hard ot get in and out lube the o-raings and go at it
04-18-2012, 06:05 PM | #7 |
Re: freon removal
One more question can the oils be mixed, pag 46 and pag 100?
04-19-2012, 03:45 PM | #8 |
Re: freon removal
Got it all back together today and after vacuum tried to charge, it is cool here today around 60 with low humidity , the system would not take the Freon. I got about 15 oz in and the clutch is at least starting to cycle. The hose line past the orifice freezes up when the engine is at 1500 RPM and then quickly un-freezes back at idle.
Is this normal on cool days or do I have a problem I have over looked?
04-19-2012, 04:11 PM | #9 |
Re: freon removal
if it is frezzing its low on freon. when i charge them by can i jump the pressure switch the the clutch is engaged all the time as i pull freon in
04-20-2012, 06:17 PM | #10 |
Re: freon removal
we used to have do service these huge air conditioner machines at work, and by law we had to have epa out there to relieve the stuff. i still dont know how to get a hold of those guys.
2001 Tahoe 1978 K30 |
