04-17-2012, 07:42 PM | #1 |
Original gas tank color
Hi all,
I'm replacing the gas tank in my 65 due to leakage. The new/used tank had been painted black. I'm in the process of stripping it and the tank looks like the rear had no paint and the front half was originally painted the fawn interior color. Is this the way they were painted when new? |
04-17-2012, 08:04 PM | #2 |
Re: Original gas tank color
I believe they were bare metal when new. Get a 2nd opinion though - to be fair, I'm somewhat guessing/somewhat basing on experience.
04-17-2012, 10:54 PM | #3 |
I just pulled the original out my 64 and it's bare metal.
Might have been galvanized even. |
04-18-2012, 12:02 AM | #4 |
Are you guys saying your WHOLE tank is bare metal? or just the backside? Every truck I have owned (all west coast) has had a fawn painted tank like the rest of the cab. Never pulled one out to check the backside though. A charcoal colored cardboard panel concealed it all when new. Very few of these panels remain intact.
04-18-2012, 12:06 AM | #5 |
Here's what mine looked like.
Nevermind the rat sh!t. |
04-18-2012, 12:08 AM | #6 |
My mounts and the tank appear to have been untouched. With that said, here is a picture of my tank from when I installed the new sending unit. It appears to be fawn.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
04-18-2012, 03:23 AM | #7 |
mine before i pulled it out to clean up behind it.same color on the backside.
04-18-2012, 08:20 AM | #8 |
Another vote for fawn, front and back.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
04-18-2012, 09:29 AM | #9 |
The one in my 60 is bare metal, front and back. BUT.... the inside of the cab is silver, so if the tank received some over spray somehow, there'd be no way to tell. Might be where the faun paint is coming from, idk.
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
04-18-2012, 09:32 AM | #10 |
My 63 was only painted on the side facing the back of the bench, and it has never been removed, but I have a 66 tank that is painted on both sides (also was never removed prior to me removing it) with the fawn paint. Maybe the early 60-63 were raw or only painted on 1 side...it seems the 64-66 guys are saying both sides are painted. It'd be interesting to know if it was left up to the assembly plant to decide. Maybe some plants did and some didn't.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-18-2012, 10:02 AM | #11 | |
04-18-2012, 10:53 AM | #12 |
That tank was out of a 61 apache 1/2ton. Very cool that you found the inspection mark. I dont know that I have ever seen one on a tank.
04-18-2012, 11:32 AM | #13 |
All the ones I've owned were all bare galvanized-cab painted first, then tank installed-all are from the St Louis plant.
04-18-2012, 01:43 PM | #14 |
My original in the 65 has been brush painted. I went out and scratched some away, fawn towards the seat back, galvanized toward the bed. Baltimore plant. Appears the cab was painted before tank installation. Do you have the vin for the 61 Jon? Curious as to the build location.
04-18-2012, 02:24 PM | #15 |
I dont have the number on me, but I do know it was a St. Louis plant truck. Spent its whole life in Missouri until the last year or two.
04-18-2012, 02:24 PM | #16 |
My truck was built in Baltimore and is only painted on the front
04-18-2012, 07:20 PM | #17 |
ok 64GMC just looked at tank and it is painted grey. paint behind tank is gray looks to not have been repainted. is this right?
04-19-2012, 07:28 AM | #18 |
MY 60 C-10 was built in Norwood, Oh. Again, it's bare steel front and back...
04-19-2012, 07:58 AM | #19 |
Here is a tank that was pulled from a 66, painted fawn on both sides from factory. Inspectors stamp still visible on bottom of tank.
