04-17-2012, 10:32 PM | #1 |
Would it be ok?
The tires that are on the truck are not the best and I have just kept them on to get it from the shop. Well one of the rear tires will not hold air anymore and I cannot find a used 255/70/15 anywhere in town, since in a week I will be replacing all 4 with brand new 255/70/15. Closes used tire I can find is a 275/60/15. My question is would it be ok to just use that to get it back from the shop, it's about 15 miles away? Would it hurt anything or be fine for the time being?
1972 C10 SHORT BED, BLACK ON BLACK, ZZ3 CRATE MOTOR WITH B&M 250 SUPERCHARGER, HEADERS, 350TURBO TRANS, BOOST RETARD, POSI, 373 GEARS 1966 MUSTANG COUPLE, 289 HIPO MOTOR, CAM, 650 HOLLEY CARB, FULL LENGTH HEADERS, 2.5" FLOWMASTER EXHAUST, HURST SHIFTER, 373 GEARS POSI 2006 MONTE CARLO, FLOWMASTER MUFFLERS, K&N INTAKE, EXTERIOR MODS |
04-17-2012, 10:36 PM | #2 |
Roadtrip!
Re: Would it be ok?
Just put the matching pair on back and run the odd one up front. You should be fine.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-17-2012, 10:39 PM | #3 |
Re: Would it be ok?
k, thanks, what would it hurt if I put the odd one on the the rear? Rear end?
04-17-2012, 10:45 PM | #4 |
Re: Would it be ok?
Yes it could potentially mess up your rear end with your rear axles trying to turn at two different speeds.
1972 K5 CST |
04-17-2012, 10:48 PM | #5 |
Re: Would it be ok?
K, that is what I was thinking. I have never had a hard time finding a place to get a matching used tire. 255/70/15 must be a used weird tire around here. Can't wait for the new ones. Thanks for all the information guys.
04-17-2012, 10:51 PM | #6 |
Re: Would it be ok?
yep -I think you'd be ok for either the odd ball front or back. 275-60-15 and 255-70-15 are approx the same diameter (but might want to messure just to make sure), that's all the rear end cares about. If they were more than about a 1/2-1" difference in dia, then I'd put the oddball on the front for the reason 72 K5 mentioned. Ok for SHORT term only I believe. Different widths (or diameters) will affect handling if they're on the front, but probably ok for short term and shouldn't damage any hard parts on the front end.... Assuming you can't take your leaker to the tire shop to get it plugged?? Anyway, should be ok, front oddball probably a better bet than rear. Drive slow, be careful, all that motherhood...
04-17-2012, 10:58 PM | #7 |
Re: Would it be ok?
Oh yeah, I will be driving slow and careful, like stated before these tires suck anyways. No I couldn't take the tire in to get it plugged it was in to bad of shape and old. Since my truck has posi it would be more at risk for damage right?
1972 C10 SHORT BED, BLACK ON BLACK, ZZ3 CRATE MOTOR WITH B&M 250 SUPERCHARGER, HEADERS, 350TURBO TRANS, BOOST RETARD, POSI, 373 GEARS 1966 MUSTANG COUPLE, 289 HIPO MOTOR, CAM, 650 HOLLEY CARB, FULL LENGTH HEADERS, 2.5" FLOWMASTER EXHAUST, HURST SHIFTER, 373 GEARS POSI 2006 MONTE CARLO, FLOWMASTER MUFFLERS, K&N INTAKE, EXTERIOR MODS Last edited by BLOWN72; 04-17-2012 at 11:09 PM. |
04-18-2012, 12:07 AM | #8 | ||
"I ain't nobody, dork."
Re: Would it be ok?
Put the odd one on the front if you like your Posi.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-18-2012, 11:57 AM | #9 |
Re: Would it be ok?
My buddy found me a 265/70/15 this morning so I will be putting that on and will feel a lot better about driving it
