Old 04-18-2012, 12:32 PM   #1
JESSEGALLEGOS
JESSEGALLEGOS's Avatar
Blazer lowered need help finding shocks!
I have a 1982 K5 blazer lowered with spindles and springs and I am in need of shocks that have a collapsed Length of around 7-8". Right now they are at 9" and only have 1+" of travel and of course are blown.
1982 BLAZER 2WD
http://img.photobucket.com/albums/v7...t/145c37fd.jpg
JESSEGALLEGOS is offline   Reply With Quote
Old 05-03-2012, 10:30 PM   #2
gearheads78
gearheads78's Avatar
Re: Blazer lowered need help finding shocks!
TTT looking for the same answer
gearheads78 is offline   Reply With Quote
Old 05-03-2012, 10:37 PM   #3
JESSEGALLEGOS
I've looked and think that something like this maybe the only solution
1982 BLAZER 2WD
Old 05-10-2012, 10:27 PM   #4
bagged74
its just $$$$$
bagged74's Avatar
I've never had any problem running stock shocks on the front, even with bags
bagged74 is offline   Reply With Quote
Old 05-26-2012, 09:51 PM   #5
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Just drill your shock mouting location higher. I have got dropped spindles and cut 3/4 ton springs. I use stock shocks, no problem. CPP.com has got some upper shock brackets for the front that are bolt on. Raises it like 3" I think. I'm using the kyb agr's I think its what their called. Great shock. I pulled them off a stock height suburban and put them on my dropped swb yesterday. Rides good.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 06-28-2012, 04:46 PM   #6
made2drag
made2drag's Avatar
the shortest ive found were for my 67 c10 front shocks. they may be the same exact shock as squarebodies but it wouldnt hurt to check. i think it was like a 8 1/2 collasped length. air shocks for a vw are about 9 and i have a pr of qa1 shocks that were 8
made2drag is offline   Reply With Quote
