Old 05-08-2003, 07:22 PM   #1
69sixpackbee
Question about windshield sealing
Do I need to put sealant on the windshield when I reinstall it with the new rubber? If so, what do I use and where do I put it?
Thanx!
69sixpackbee is offline   Reply With Quote
Old 05-08-2003, 07:35 PM   #2
cruzn72
window seal
I could not get the window on my 72 gmc to seal. I had the glass shop seal it. They sealed between the gasket and the window frame. They told me the frame has drain holes that become clogged or damaged (I do not know if this is true or not). I do not know what they used but it worked, I have not had a leak for 5+ years.
cruzn72 is offline   Reply With Quote
Old 05-08-2003, 07:43 PM   #3
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
Supposedly it is not needed. The rubber fits tight and is difficult to put in, so depending on the condition of the metal around your window you should be okay.
The first time we installed it the window got broken in the upper passenger side do to the tight fit. We used 3M window sealer and it made a mess.
The second window went in easier with no sealant, and it hasnt leaked yet.
Hope this helps. Just be sure to work the window and rubber in slowly and take your time.
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 05-08-2003, 07:46 PM   #4
69sixpackbee
I'm going the "let the gasket soak in the sun for a while and use the string and soapy water" method and was wondering if I needed "goop" Thinks I have my answer.
Thanx!
BTW DanoMano..I've been to your neck of the woods. My sister lived in Gig Harbor. Say, isn't Puyallup next to, dare I say, "'Till I cum"?
Old 05-08-2003, 08:33 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i got a friend at a body shop who told me to use that brown gasket junk to seal the windshield the downsides are ya gotta be careful not to get stuff on the paint as its hard to get off and the only way youll ever get that gasket off again is to mangle it SO next windshield youll have to get another gasket
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-08-2003, 08:50 PM   #6
DanoDMano
DanoDMano's Avatar
Too funny 69 1/2, Yeah thats the name. It is just a little north
of the "Skoo- Cum- Chuck" river....
He He....
Power Locks,
Truck Photos
Old 05-08-2003, 10:00 PM   #7
Tuck
Just put the front and rear windshield in last night. I used Go Jo hand cleaner for lube. The old lady and me got both installed in 20 miniutes. with the rope trick.
Go jo is your friend. and cleaned the gasket real nice.
Tuck is offline   Reply With Quote
Old 05-09-2003, 11:34 AM   #8
69sixpackbee
Go-jo it is..thanx Tuck, et. al..!
Old 05-09-2003, 01:42 PM   #9
Tuck
dont forget the top goes in first, if you put the bottom in first you will break off the corner.
Old 05-09-2003, 01:45 PM   #10
69sixpackbee
Thanx for the tip, Tuck! I was going to try bottom up.
Old 05-09-2003, 02:00 PM   #11
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Tuck; I'll send you my address. When can you get here to do mine?
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-09-2003, 02:16 PM   #12
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Tuck, Hey thanks for the tip. I have done my rear window...it is a piece of cake...took 5 minutes tops. I was reluctant to try the front. Can you just insert the entire top edge by sliding it up the front of the cab since the hole is bigger on the bottom or do you insert one corner first and start the rope work on top? Yu da man!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 05-09-2003, 04:43 PM   #13
Tuck
Its top corner in them the other sides top corner. rope is centered on the top. start pulling one side while someone puts pressure on it from the outside. I do half the top then down one side, then half the top down one side then the bottom.
Hey PA guy, how far are you from Springdale? I will be out that way in a week or so. If your close I will bring the rope.
Old 05-09-2003, 06:18 PM   #14
Boardrider52
Boardrider52's Avatar
my dad owns a glass shop in phoenix and i think they put a cocking sealant between the window frame and the rubbers
72' Jimmy
member of Above~n~beyond truck club
members.fortunecity.com/aboveandbeyondtrucks
Boardrider52 is offline   Reply With Quote
Old 05-09-2003, 06:19 PM   #15
Boardrider52
you also have to really bang the window in there too get the seal down, and it takes a lot of force to break a windshield
72' Jimmy
Old 05-09-2003, 10:28 PM   #16
Dads72
The factory manual says to put some sealant on (in between) the top corners of the front windshield. Like maybe a 6" bead out from each corner.
The guys who put mine in said to leave it alone for awhile and let everything settle.
If you seal it when you first install it, the sealant could take a "set" and then crack the glass later on.
Don't know if this is right. Just telling you what I was told.
No sealant on mine yet - and no leaks.
Dads72 is offline   Reply With Quote
