Left turn signal issue
hello, i have recently put LED lights in place of the taillights and they have been working great. my right turn signal works great. just like it did before the replacement. now the left turn signal works when the parking lights are off, but flashes at a different speed from the right turn signal. when the parking lights are turned on the left quits working and the right works like it always does. any suggestions?
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear! 1969 C30 Open Road Motorhome 350/th400 1972 K10 350/350/205 Daily Driver -SOLD |
Re: Left turn signal issue
Check your left front bulb. If the bulb is ok, check its ground. I'm betting the turn signal element in the front bulb is fried.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
i just went out and checked, when the left turn signal is on, the front does not blink. when the right is on both front and back blink. i switched the front bulbs and the right still blinks, the left does not. so i know it is not the bulbs. any other possible solutions? all fuses are intact
#4 | |
On my truck the ground is good but there is a bad connection in the lamp holder. If I jiggle the lamp holder where the wires go into it, it works. I need a new lamp holder which on a 69/70 is the assembly that is attached to the grill. (In my case it is the parking light that is intermittent. In other words the blinker always blinks on command but the parking light doesn't always light up when commanded)
