Old 04-18-2012, 01:03 PM   #1
AZ59apacheguy
Help with identifying a Chevy Truck Bench seat
So I bought this bench seat from a local guy on craigslist to put in my '59 1/2 ton, he sold as being a seat out of a '57 1/2 ton. I took his word on it, bought it, brought it home, tried installing it and what do ya know, it doesn't fit. Both the mounting brackets and physical size were TOO large. Can you guys please help me identify this seat so I can sell it for the right type of truck. I was told it might be for a '60 to '66, can someone confirm that? Thanks
Here are the dimensions:
Front Bracket mounting hole spacing= 50" & 42.5"
Rear Bracket mounting hole spacing= 49" & 44.5"
Bottom seat= 57.5" Long, 22" Deep
Back Rest= 59.5" Long
Here are some pics:
http://i1236.photobucket.com/albums/...y/IMG_1226.jpg
http://i1236.photobucket.com/albums/...y/IMG_1225.jpg
http://i1236.photobucket.com/albums/...y/IMG_1227.jpg
http://i1236.photobucket.com/albums/...y/IMG_1229.jpg
AZ59apacheguy is offline   Reply With Quote
Old 04-18-2012, 01:06 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Help with identifying a Chevy Truck Bench seat
That frame appears identical to the bench seats from our V8 era trucks...a side shot of the seat and the back frame and stop will help.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-18-2012, 01:16 PM   #3
1963c-10
1963c-10's Avatar
Chevy used the same bench seats for L6 & V8 engines 1960-66
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-18-2012, 01:17 PM   #4
AZ59apacheguy
Hi, thanks for the reply. Excuse my ignorance, when you say V8 era trucks, do you mean 60-66 V8 models? I can get those picks you requested later this afternoon.
Old 04-18-2012, 01:20 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
That is definitely 64-66. I dont know about 60-63 since Ive never violated one.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-18-2012, 01:30 PM   #6
1963c-10
1963c-10's Avatar
The bench seats were the same for 60-66. I have about 4 of them laying around, some out of V8 trucks, some out of L6 trucks, taken out of a 61, 63, 65, 66 and cannot tell the difference in the frames or tracks. the upholstery is the only difference.
Old 04-18-2012, 01:51 PM   #7
vin63
vin63's Avatar
Yes, the 1960-66 trucks were referred to as the "V8 era," even though many came with the L6. This model grouping term is similar to the previous generation trucks (1955-59) being referred to as the "Task Force era" trucks. Just for reference, the 1947-55 trucks are referred to as the Advanced Design era trucks.
Old 04-18-2012, 02:22 PM   #8
1963c-10
1963c-10's Avatar
Ive never heard of that, but makes sense. Ive heard of the Task Force and AD trucks though. Learn something new every day.
Old 04-18-2012, 02:52 PM   #9
factorystock
factorystock's Avatar
The "V8 era" was just one authors labeling of the 60-66 design cycle. Yes more and more V8's were installed year after year, but the majority of 60-66 trucks were still 6 cyl. powered during this era. The 67-72 cycle was definately the "V8 era".The 60-66 era should have been labeled the "smooth ride era". Everyone can can up with there own label, but history will show these were the first generation of "modern trucks" built by GM.
factorystock is offline   Reply With Quote
Old 04-18-2012, 03:16 PM   #10
1963c-10
1963c-10's Avatar
Ive just always called them 1st gen c-10's
Old 04-18-2012, 03:19 PM   #11
vin63
vin63's Avatar
Geez...technically the first generation of the C/K Series trucks. How's that? More than one person has referred to the first gen C/K Series trucks as the V8 Era.
Yes, that bench seat appears to be from a 1960-66 GM truck.
Old 04-18-2012, 04:10 PM   #12
1963c-10
1963c-10's Avatar
I agree with you, its just a term I hadn't heard before.
Old 04-18-2012, 08:41 PM   #13
AZ59apacheguy
Thanks for the help. Seat sold today and is going to someone who can actually use it.
Old 04-18-2012, 09:43 PM   #14
chevyguys
I Got it BAD!
chevyguys's Avatar
Btw. That is a 64-66 custom comfort seat with the full depth foam.
Build Thread: http://www.chevyguys.com
chevyguys is offline   Reply With Quote
