Old 04-18-2012, 02:01 PM   #1
jessewebb
jessewebb's Avatar
Rear Sway Bar Instructions
I bought a rear sway bar from a member awhile back and am just getting around to installing it and am at a loss. I have no idea on how to mount it, or where to mount it. I have coil springs on the rear. With the trailing arms. I took a couple of pictures i will post. Any help on this would be appreciated. Thanks Pete
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 04-18-2012, 02:40 PM   #2
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Re: Rear Sway Bar Instructions
http://www.classicperform.com/Instru...PDF/CP7401.htm
this should get you close
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 04-18-2012, 04:30 PM   #3
jessewebb
jessewebb's Avatar
Thanks for the info.
Pete
04 325i lady's ride
Old 04-18-2012, 04:58 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Be sure to post up some pics when you're done...might make a good future faq!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-18-2012, 05:11 PM   #5
jessewebb
jessewebb's Avatar
I hope to get it on by the weekend. I bought some 2" drop blocks. I think I'll inatall those first. Don't want to have to redrill the holes.
Pete
04 325i lady's ride
Old 04-18-2012, 05:22 PM   #6
jessewebb
jessewebb's Avatar
By the looks of the pictures I posted. I don't see the L bracket there showing. I bought that awhile back. Guess I should have done my research then. I don't even remember who I bought it from now. Guess I'll have to rig something up. Oh well somebody has a set of L brackets without a sway bar
Pete
04 325i lady's ride
Old 04-19-2012, 12:04 AM   #7
BuiltwithIvy
the angle piece is made out of 1/4" thick x 2" angle iron, the frame side is drilled 3/8" with a bolt, lock washer, and nut, the bar side is drilled to the "nipple" of the bushing. don't know if nipple is the right word, but it works well enough I guess
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 04-19-2012, 06:22 AM   #8
jessewebb
jessewebb's Avatar
I was hoping that would work. I was thinking the same thing. Thanks
Pete
04 325i lady's ride
