dropping my truck
I am planning on droping my 67 buy cutting the springs, I know this is not the best way but i am on a budget it and this is just for now. My question is how do i know how much to cut? i want about a 4" drop so how much spring should i cut? thanks
senior member
1 full coil
i would also recomend getting a wheel alignment when ur done even tho they will have to shim the hell out of things
69 GMC bagged |
1 full coil will make for 4 inches? and what do u mean by shim the hell out of it?
thanks |
Start w/1 coil & then cut 1/2 a coil @ a time after that to get what you want. You will have to use extra shims for the upper a-arms in order to achieve proper (or close to proper) alignment.
Some advice. . .... once you trim 2 coils off the front springs, the coils can easily come out of the spring pocket if the suspension becomes unloaded (like if you were to hit a big dip in the road & the truck rises rapidly). I've been in a buddies truck when this happened & it was a very scary moment. You'll also have a hard time getting someone to align the front w/only cut coils for the drop. With some drop spindles & 1 coil off you'll get 5" drop, a decent ride & still be fairly easy to align. Good luck.
aka Crusher, Crushergmc
I've heard not to cut more than 1 coil or you'll have some bumpsteer. I cut 1 but haven't driven it yet. Good luck.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
thanks guys. but what is bumpsteer?
That's when severe angle of the tierods causes the steering to pull whenever going over bumps in the road.
Cut coils don't accomodate for this & that's the reason for 'bumpsteer'. Drop spindles have the steering arm modified to compensate & allow the tierods to parallel the a-arms (which should be level to the ground).
Out of the carpool lane.
You should be fine with exactly 1 coil cut or less. Use a grinder with a cutoff wheel or similar when cutting, as a torch would change the temper of the steel. Be aware that you can't cut rear springs due to the pigtails on both ends. I've even lowered mine using the torch to heat the springs and I was just fine. Mine were 31 year old springs at the time. But, this isn't recommended - only a short term solution until you can afford drop springs and spindles.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
