Old 04-18-2012, 08:46 PM   #1
Belairbob
WTB Crank/PS pulleys and valve covers
I need a 2 groove crank pulley, 1 groove PS pulley and some original style valve covers for my 72 with 350 engine. No bends or dents please. Thanks, Bob
Belairbob is offline   Reply With Quote
Old 04-19-2012, 01:28 AM   #2
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Re: WTB Crank/PS pulleys and valve covers
I am going subscribe to this, if you dont get help on it before Monday I think I can find this stuff for you. (I can't check until Monday). Good luck!
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 04-19-2012, 02:15 AM   #3
tll74
"Junkyard Dog"
tll74's Avatar
15.00 on the crank pulley, 25.00 on the valve covers, hot tanked & dipped. Like new. Which P/S crank pulley do you have? Is it cast iron or stamped steel? The crank pulley determines which pump pulley is used. Plus shipping.
Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 04-19-2012, 02:20 AM   #4
68shortfleet
Thanks, Tom
Any chance you know casting/stamping numbers of which crank pulleys combine with which water pump and power steering pulleys?
68shortfleet is offline   Reply With Quote
Old 04-19-2012, 06:37 AM   #5
Belairbob
Thanks, Tom
I don't have either pulley. I'm asking for both the crank pulley and a P/S pulley. The P/S pulley would be for a pump whose shaft is threaded for a nut. Or at least that is what I see in picture posts as original to our generation of trucks. But do correct me if I'm wrong!
Thanks,
Bob
Old 04-19-2012, 10:59 AM   #6
Belairbob
This is for an early 80's block as far as I can tell. It currently has a steel crank pulley for a long waterpump. I'm changing to a short pump along with brackets etc. needed for P/S pump and Alternator. You have me wondering if a cast crank pulley, which would weigh more, works with the balancing of the rotating assembly? In other words if I put on a cast crank in place of the steel would it throw it out of balance?
Old 04-19-2012, 11:13 AM   #7
southern parts
southern parts's Avatar
your engine is internaly balanced, the pulleys wont effect it. sounds like you need a complete set of pulleys, 2 that bolt to the balancer, 1 for the waterpump, and 1 on the ps pump.
southern parts is offline   Reply With Quote
Old 04-19-2012, 04:34 PM   #8
teeitup
Just like to part out trucks!!
teeitup's Avatar
I will have all the motor pullies and valve covers on a truck I just hauled in. I have the ps pulley but its on a pump and brackets. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 04-20-2012, 02:10 AM   #9
tll74
"Junkyard Dog"
tll74's Avatar
Sorry, I don't have a pump pulley separate from a pump assy. 27.50 for both crank pulley's. Thanks, Tom
Old 04-20-2012, 07:25 AM   #10
Belairbob
So, mostly likely my truck originally came with a single groove steel crankshaft pulley with an add on pulley behind it for the P/S pump?
Would that then affect the water pump pulley alignment?
Sounding like I need to find a set of 4 - W/P, C/S and addon for P/S, and the P/S pulley to insure they all line up correctly. Is that the better approach?
Old 04-21-2012, 01:18 AM   #11
tll74
"Junkyard Dog"
tll74's Avatar
I have all the pulleys except for the pump pulley out of one truck. I can give you the part number stamped in the correct pump pulley to match. I would remove it from the pump for an additional 25.00 if you wanted. Taking it off the pump seems to be a deal killer for selling the pump assembly. Thanks, Tom
Old 04-21-2012, 08:20 AM   #12
Belairbob
What would be the total for all the pulleys including the complete pump assembly? Also including the vavle covers. Shipping to 27502.
Thank you Tom,
Bob
Old 04-21-2012, 12:58 PM   #13
tll74
"Junkyard Dog"
tll74's Avatar
Thank you Tom,
Bob
Bob, 110.00 fo the parts (two groove crank pulley, single groove crank-P/S pulley, complete pump assy, and pair of 72 valve covers). Shipping 22.50 so the total would be 132.50. Thanks, Tom
Old 04-21-2012, 08:25 PM   #14
Belairbob
PM sent.
Thanks to all who replied!
Bob
