Headers VS Manifolds?
im running flowmaster original 40s im getting sick of the headers always leaking or spark plug getting burnt, id like to switch to manifolds but i really dont want to loose that good sound? will i really notice that much of a difference in sound and performance? its on a 350 v8
Re: Headers VS Manifolds?
use good gaskets, cut the flanges, and use exhaust wrap. my plain-jane steel ones are wrapped and sealed and they run cooler than my manifolds used to. no leaks, no burnt plugs
18 Till I Die
Im gonna try it but not for a few months yet...Your right headers can be a pita on a driver
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
What brand headers are they?Cheap ones the main flange will bend with use making them leak.
header gaskets are just a pain, there meant for gasket matching which isnt needed really. Id look for the 6 piece manifold gaskets, they sit right in place on each set of ports. Ive heard these work better. Good luck!
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play ![]() |
#6 | |
![]() Posted via Mobile Device
Had some accel 8.8 race wires. They touched the headers for six months with no issues. Also look up REMFLEX gaskets. They will seal 100% of the time all the time. Cut your flanges to allow some flex. And use header lock washers.
If all this doesn't work and your headers aren't warped. I will eat my shoe!! Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#8 | |
78K & 79C Jimmys
I did grind out those nibs in the manifolds
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 04-19-2012 at 01:10 PM. |
Parts and more parts
Where are your leaks on the headers? I have been running headers on my trucks for years and I have found that I can control that problem by doing a couple of simple things. First I use either the copper header gaskets or a set of Felpro header gaskets that are coated with "Coppercoat" high temp sealer. It does work on the headers. I also use the gasket sealer on my collector gaskets and if I have to , I double up the gaskets at the bottom.
Now for a trick that I read in Hot Rod many years ago. Put teflon tape on your header bolts. This simple thing will keep your header bolts from backing out of the heads and when you want them out, the bolts will come out without a lot of effort. When you are ready to use them again, just clean the bolt with a wire brush and put more teflon tape on them. I can put a set of bolts in, heat up the engine and snug them one last time and they last for years. That is IF you have a good quality header flange on your headers to start with.
Frank |
