04-18-2012, 11:55 PM | #1 |
alternator threads stripped:(
I was replacing my serpintine belt, loosened the alt bolt so I can move the alt from left to right, replaced serp belt and went to tightened alt up and my thereads were stripped the alt is in good shape but I can't tighten it down because the threads are stripped. Any suggestions on how to save the alt besides making new threads?? I don't have a tap n dye to make new ones so I'm open to suggestions... Please. I don't wanna have to buy a new alt.
-Samuel "Knowledge Is Power" |
04-19-2012, 12:09 AM | #2 |
18 Till I Die
Re: alternator threads stripped:(
I have seen a bolt right thru with a nut on the other side.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
04-19-2012, 12:24 AM | #3 |
I have done this on more than one occasion.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
04-19-2012, 12:37 AM | #4 |
Same, have done this many times, drill it out with a 5/16 bit and bolt her up.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
04-19-2012, 12:40 AM | #5 |
Install a helicoil I use them all the time
Posted via Mobile Device |
04-19-2012, 04:53 AM | #6 |
My friend used 12 bungee cords....
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
04-19-2012, 09:02 AM | #7 |
Robert Olson Transport
ill third the nut and bolt but also use a lock washer too
Insidious you dont need 12 bungee cords ten good rubber bands will do the trick
04-19-2012, 09:25 AM | #8 |
Thread tap is easy to use on an already threaded hole, and you can pickup a complete tap and dye set set for 20 - 25$ at your local auto parts store. I would recommend this first as its a handy tool to have around.
But you can always drill it and nut/bolt it. |
04-19-2012, 09:50 AM | #9 |
Tap to next larger bolt
Helicoil to repair whats there. Bolt through.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
04-19-2012, 11:17 AM | #10 |
I (what fourth?) the motion for a nut on the other side. I have that on my alternator right now. Works just fine and the alternator bracket already has a hole in the side for a wrench to fit through for the nut. I used a star locking washer as well for the extra security.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
04-19-2012, 06:17 PM | #11 |
Ive tapped up to the next size bolt in the past.
