Old 04-19-2012, 05:06 PM   #1
GMC1965
Floor not level? Rusted
My cab supports are pretty rusted and the bolts in the floor are no longer there. I will replace the front supports and fix floors. The problem is the cab floor seems to not be level. They slant from the middle to the doors. Is this the right way or are my floors bent? I am going to be removing cab and it seems that I need to weld in support bars so the cab does not move. with floors not straight is this a problem? Doors are pretty good closing and opening. Just the hinges need rebuilding, I have the parts.
GMC1965 is offline   Reply With Quote
Old 04-20-2012, 07:58 AM   #2
koda360
koda360's Avatar
Re: Floor not level? Rusted
They should slope from the trans hump toward the doors, in the front where your feet go. The higher portion under the seat should be flat.... Is that what you're asking?
1960 C-10
2000 Dakota R/T
1966 Fury I 2dr post
1984 Big Bronco
2002 Durango SLT (Bride's Ride)
koda360 is offline   Reply With Quote
Old 04-20-2012, 08:22 AM   #3
GMC1965
Yes! Thank you! The floors did apear to be more sloped then I thought it would be. I just guessed seeing as theirs rust that may be the issue.
