04-19-2012, 05:39 PM | #1 |
Wtb 3500 emblems
I got a 91 sub an it has the lower trim like the newer trucks an I'm looking for a set of 3500 emblems for the doors
Posted via Mobile Device |
04-20-2012, 09:13 AM | #2 |
Re: Wtb 3500 emblems
You might have better luck looking in the 88-98 parts board since the '91 Suburbans used that style trim and went by 1500 rather than 10,etc
04-20-2012, 09:46 AM | #3 |
Getting Old; Going Broke
Testing my memory pretty good here, but here goes. Since the R/V suburbans were not offered in a 3500, I'm pretty sure the exact emblem you're looking for does not exist? The R/V 1 ton square body trucks had door emblems, but I'm not sure they ever put body side moldings on those trucks. First picture from Mitchell showing part #'s, is from a 91 C3500 (new body style). Second picture is from a 91 R30 crew cab. It does not show the emblem with or without side moldings, just an emblem. Hope anything here helps, at least they do not have the dreaded "d" by them that means discontinued so maybe you can find them from your GM dealer with any luck.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
04-20-2012, 11:43 PM | #4 |
I have a set off my 97 but they are made diff the 91 emblem as a raised peice on the back of it that locks in the moldin . Will post pic of it tomorrow
04-21-2012, 12:10 AM | #5 |
All the emblems made to go in the moldings had tabs on them to fit in a notch in the door molding, all the way up to 98. The emblems made to go directly on the door skin were just flat, but I seen them used a lot on moldings when people would add moldings to their Cheyenne base truck.
04-21-2012, 08:06 AM | #6 |
I think the emblems that are on my '92 K3500 SLE (has molding) would work. The '91 Suburbans came with the same type moldings and were located on it,but on;t 1500 & 2500. I think the C/K 3500 emblems will work and look factory
04-21-2012, 08:34 AM | #7 |
Thank I will check out some trucks with the side molding my 97 didn't have the moldings down the side of the truck an the emblems were just stuck to the doors
04-21-2012, 10:08 AM | #8 | |
Like I mentioned, the first photo I posted up top is a screen shot of 91 C3500, two different emblems, with or without molding. You are wanting with molding so they have the tabs.
04-21-2012, 11:35 AM | #9 |
Correct
