Old 04-19-2012, 10:59 PM   #1
Bardahl
3 spd manual swap out for tilt/700r4
I am gearing up to swap out my 3 speed manual for a tilt wheel/700r4 on my long fleet 68 anniversary pick up,I have a rebuilt tilt column,and automatic frame/shift brackets, I have trans (non computer) w/converter, think I need auto cross member, (will drive line need altered?) what else/, which ring gear (#of teeth) for 2 bolt starter? any and all help would be appreciated, i want to have all parts I`ll be needing to have before I start the conversion any and all help is really appreciated.
Bardahl is offline   Reply With Quote
Old 04-20-2012, 12:14 AM   #2
Bardahl
Re: 3 spd manual swap out for tilt/700r4
Moved where????????? can anyone even see it now??????? Thanks i think??
Old 04-20-2012, 12:15 AM   #3
dan42
dan42's Avatar
What are you going to do about the extra pedal?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-20-2012, 12:56 AM   #4
rocknss
rocknss's Avatar
You will need to have the drive shaft shortened. Will need an auto flex plate and auto starter. Shift linkage for trans, TV cable, longer speedometer cable and correct drive and driven gears for the trans so speedo will work correctly.
rocknss is offline   Reply With Quote
Old 04-20-2012, 07:57 AM   #5
mrein3
mrein3's Avatar
Ha!
When I swapped out my 3-speed manual for a th350, I drove around for a couple of years with an extra pedal.
When I finally looked under there it was laughingly simple to remove.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-20-2012, 09:11 AM   #6
Bardahl
The peddle is no problem, i should be able to shorten the drive line the difference of the transmissions lenghths, correct ?? what exactly is TV cable and what is the preference and why ? I am close to having everything set to go, thanks for the answers from all.
Old 04-20-2012, 12:07 PM   #7
rocknss
rocknss's Avatar
The TV cable is the Throttle Valve cable that goes from the 700R4 to your Carb. Its very important that it is set up correctly so you don't kill your trans.
Old 04-23-2012, 10:56 PM   #8
Crabass
Where are you gonna hook up your trans cooling lines? And take Rock's advice about the TV cable VERY seriously.
Crabass is offline   Reply With Quote
Old 07-30-2012, 10:38 AM   #9
Bardahl
Finally have tilt/trans mounted, I need 2 1/4 " cut off drive line but found a stock driveline out of another 68 LWB I had w/auto, it is 2" shorter already should work??, anyone have the info will a drive line (2piece) out of a stock 3 speed auto work on the same truck when changing to 700r4??
Old 07-30-2012, 04:25 PM   #10
Jurassic-1
Jurassic-1's Avatar
You may need a special adapter for the throttle shaft on the carb. Most 700R4 transmissions were from fuel injected vehicles. The carb. link will not allow Wide open throttle pressure to the trans. This will toast it pretty quickly. I purchased the adapter from Bowtie overdrives. It is fully adjustable which is a unique feature. Chec them out. There are a couple other companies who offer similar brackets.My 72 blazer went from undrivable on long trips to a cruiser . It runs about 2300 rpm at 70 in lockup mode.
Jurassic-1 is offline   Reply With Quote
Old 08-04-2012, 12:14 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
700r4's came out in '82. Fuel injection introduced in '87. 4l60e introduced in '93 so going by years produced, nearly half were behind carbureted engines. I used to rob all of the tv cable brackets I could find on carb'ed vehicles in the wrecking yard. At one time you could buy the bracket for a 700r4/ 200 4r over the counter at GM. I'm not sure if that is still the case or not. Aftermarket has it covered anyway. TV cable adjustment is extremely important. I have a 700r4 in y barn that was supposedly rebuilt and burnt up in less than a day due to a Lokar cable being bound up (according to P.O.) I picked it up for $75 as a core.
WIDESIDE72 is offline   Reply With Quote
Old 08-04-2012, 12:51 PM   #12
Bardahl
got the 700 R4 in and drove it yesterday around the block, had the drive line rebuilt and shortened (measured diference in transmission length) and installed it and it was too long still, CORRECT WAY TO MEASURE EVERYTIME is from the end of the out put shaft of transmission to the center of the bolt holes on the carrier bearing bracket on the truck, had to learn this from driveline services in Portland, luckily they are 15 mins from my house. also 3 speed manual driveline had same spline as 700 r4 output does. now need the TV bracket for carb !
Old 08-04-2012, 01:42 PM   #13
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
You must heed the warning the other guys have given you about the TV cable. Driving the truck without it connected and properly adjusted will burn up your transmission in a heart beat. Checkout http://www.tvmadeez.com/ for brackets and a cable that will work with your set up.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 08-04-2012, 05:06 PM   #14
WIDESIDE72
WIDESIDE72's Avatar
X2!
Btw Driveshafts out of newer trucks will fit. I put one out of a late 80's Swb with a 700r4 in my 72. 54" from u joint to u joint for a sWb
Old 08-04-2012, 10:42 PM   #15
kevmic28
kevmic28's Avatar
So was your measurment closer to 3 inches after remeasuring it?
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 08-05-2012, 01:38 AM   #16
Bardahl
It was appx 3 1/2". The difference in the transmission lengths 3 Speed manual vs 700r4 was 2 1/4" I added 1/4" to make the first cut off the driveline 2 1/2", got it home and it was still too long, I measured the end of the 700r4 tailshaft (installed in truck) to the center of the carrier bearing mount on the truck (as instructed by the guys at driveline services) and that was 33", they had to cut another " off the driveline as mine was still 34" (front half of driveline)
Old 03-28-2013, 12:12 PM   #17
EZ SPEED
EZ SPEED's Avatar
I am starting to get my list of parts needed to do a 3 speed on the column to a 700R4 on this 67.
I plan on getting most of it from Bowtie Overdrives.com
They also have the correct TV cable to work with the Ram Jet 350 engine
I ordered the automatic column from CPP the other day
Eric
1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509
2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq
2016 Camaro SS - Satin Pearl Nero wrap
My 2010 Camaro SS Magazine feature (SOLD)
http://www.superchevy.com/features/g...of-perfection/
EZ SPEED is offline   Reply With Quote
Old 03-28-2013, 01:18 PM   #18
JOJABOY
bump
JOJABOY is offline   Reply With Quote
Old 03-28-2013, 02:36 PM   #19
Longhorn 70
Longhorn 70's Avatar
Sounds like you are doing this right! The 700 behind a RamJet is a great combo.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-29-2013, 02:22 PM   #20
stsalvage
Scrapper 1
stsalvage's Avatar
Now I've seen a lot of guys put tilt inside there trucks.If the truck is not driven very much.Then its fine but when the truck is really used Tilt becomes a pain in the BUTT.What is the one thing that you use to pull your self inside your truck on the drivers side.Now for you thine guys that weigh 150 pounds this dose not apply to you.But us guys that are 190-300 pounds and are 5'10 and above we really pull on the steering wheel to haul are Fat ass into the truck.That column bolts get offly lose.then the wheel starts bouncing to ever pot hole in the road.
stsalvage is offline   Reply With Quote
Old 03-29-2013, 02:25 PM   #21
JOJABOY
Who you calling Fat ass? LOL 6'-5" and 240 Some say your body is a temple. I say mine is a 7/11. I'm going for the AMERICAN look.
Old 03-30-2013, 01:16 AM   #22
rocknss
rocknss's Avatar
x2
Old 03-30-2013, 01:21 AM   #23
Lattimer
Lattimer's Avatar
For those of us that are 300+, tilt is a must to fit behind the wheel.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 07-14-2014, 02:14 PM   #24
EZ SPEED
EZ SPEED's Avatar
one more question...what speedometer cable do I need.. i almost have this swap finished.
the inner cable is too small and will not fit the 700r4, would a speedo cable from a th350 c10 work?? this was a 3spd manual truck
Eric
Old 07-15-2014, 10:51 AM   #25
rocknss
rocknss's Avatar
A th350 cable will work, you just need to know what length you need.
Use a rope or wire and run it the way you will run the speedo cable to get the length you need.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
