Old 04-20-2012, 10:47 AM   #1
grancuda
grancuda's Avatar
Block off center caps for Slot mags w/3.75 center hub hole
There are now block off caps being made if anyone is running slot mags that have too big of a center hole to put a regular Torq Thurst or US Indy mag style cap. I have a pair of Ansen slot mags that have a larger bolt circle for the center cap and dashman (www.dashman.net) which he can be found on ebay user 68rrman, made me some caps to fit. These block off plates will cover 3 ¾” center hub hole and work great for 5 on 5 slot mags. Not sure how many Ansen wheels are out there with the bigger caps but anyone can adapt and drill holes to make these work on big hub slots. Just thought I would pass it along as I have had multiple sets of 5 on 5 with a big hub and never been able to run nice looking caps. The caps are 2 7/16" bolt to next bolt.
grancuda is offline   Reply With Quote
Old 04-20-2012, 11:08 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Block off center caps for Slot mags w/3.75 center hub hole
Too Kool for Skool! I have a set of old ET 5 window slots, and need to cover the center holes. I have the original plastic center caps with the "ET" logo, but they are so fragile, I don't want to break them.
My mags came off of a 60's era Gasser...
Great find! I'll have to go measure my centers and bolt circle.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-20-2012, 12:21 PM   #3
BluTrukker
BOHICA
BluTrukker's Avatar
any covers for the front wheels? I have a set of jeep slots that fit pretty tight on the hubs. I can't get the bullet style push from behind style on because of tight clearance between the rim center hole and the hub.
Do these bolt to the rim or slip over the lugs?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
