1962 C10 stock frame and 78 front crossmember...
I also have the 78 stands and mounts. Eventually pulling the stock crossmember and with it will go the old front engine mount. I have 2285 SBC motor mounts on the 64 283 I want to run and I have 66 C10 stands. School me if you will it's been a long time since I put a small block in a early frame. Does the frame height require the use of a spacer on top of the frame rail? Any other points or potential problems I might have missed? Thanks! |
Re: 62 C10 V8 Engine Stands / Mounts
in the faq's. http://67-72chevytrucks.com/vboard/s...d.php?t=369663
ron |
Thanks Ron - I thought there was a spacer required.
Yes I read the article... and my first response meant to indicate I agree and I had thought so for some reason.
I remembered someone else telling me or seeing that a spacer would be required and then the article confirmed it. Thanks again! |
Sorry to dig up an old thread...
I have a 1961 Apache that has a 350 sbc, with the motor mounts on the cast iron bell housing having two contact points, and the motor mount in the front having the horseshoe collar bracket that bolts to the front of the block. Well, I rebuilt my 350 into a 383 stroker, and the harmonic balancer is much larger than the 350 stock harmonic balancer. Hence, it won't clear the horseshoe collar bracket. So...I'm going to use the engine perches from the 67 to 72 sbc, and bolt to the motor mount holes on the side of the block. This means, I now have FOUR (4) points of attachment for this block. Two in the front now, and the two original ones on the bellhousing in the rear. With four mounts, is that going to cause a problem when running the engine? The motor won't be as free to move around when giving it the gas...except for the rubber bushings... Thank you, Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
With the rubber motor mounts I think you should be fine.
Thanks Captain...it will have rubber mounts in all four corners.
Does anyone have the horseshoe motor mount bracket for sale?
speedway motors sells one thats universal for v8 chevys if you can't find an oem one and have some minor fab skills
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thank You, I'll check them out.
![]() Join Date: Dec 2007
John, I have a couple of horse shoe style motor mounts if you can't find any locally, I could ship you one cheap. I am in Arizona between Tucson and Phoenix, Az. Bob aka: Runningiron
#13 |
Thank You Bob. I found one locally shortly after posting that message, not cheap, but I found one.
#14 |
John,
Thanks for getting back with me. I still have 2 horse shoe style engine mounts. You said that they were not cheap. Do you mind me asking how much you had to give for them? I want to sell mine at a reasonable cost and not be too low or overly priced. I also have a 1960-1962 V-8 bell housing with the passenger side hydraulic clutch arm. I have seen them on e-pay for about $200. I think I'll post it with a horse shoe motor mount once I find out what the horse shoe motor mounts are going for. Thanks in advance. Bob HORSE SHOE STYLE V-8 MOTOR MOUNTS SOLD. THANKS Last edited by runningiron; 04-08-2015 at 01:02 AM. Reason: ITEMS SOLD |
#15 |
Bob,
I found the motor mount and the bell housing on Craigslist. Total cost with shipping was $185.00. I think you could get $75.00 to $100.00 for the mount alone? Good luck. John |
