Old 04-20-2012, 09:48 PM   #1
Scott26
Scott26's Avatar
does anyone know where to find EGR solenoid for carbed 86?
i found gm part number 1997658, but i dont know if its for my truck and has ca emissions. I found CRB 22292 through napa.mine has three vacuum ports and in these pictures it only has two. I thought maybe i would ask to see if anyone knows where to get one. 350 quadrajet ca emissions. They have plenty online for 87 tbi and up but not for feedback carbs. thanks
1986 GMC Sierra Classic 4X4
Scott26 is offline   Reply With Quote
Old 04-21-2012, 01:19 AM   #2
beamn7
Re: does anyone know where to find EGR solenoid for carbed 86?
Same as my truck...
Autozone part number: EVS5
beamn7 is offline   Reply With Quote
Old 04-21-2012, 01:29 AM   #3
Scott26
Scott26's Avatar
ok thanks the tbi solenoid will work? cuz it says 87 and up i was just making sure
Old 04-21-2012, 01:39 AM   #4
beamn7
Negative. The TBI one is a two port solenoid. Ours is a 3 port like in the pic I posted. They were only used on 85 and 86 CA emissioned trucks.
http://www.autozone.com/autozone/par...ier=78810_0_0_
Old 04-21-2012, 01:56 AM   #5
Scott26
Scott26's Avatar
That's weird cuz it says it doesn't fit the 86 and it says for 85 5.0 I dunno
Old 04-21-2012, 03:18 PM   #6
beamn7
Sorry, I blew in the info for my truck. Mine was originally a "F" code 305.... 355 now.
Should still be the same part as long as you have the feedback carb system with the two stage accel pump (3 connectors on carb) and it is originally built with CA emissions. Majority of the 85-86 CA emissioned trucks were 305's.....
Does the pic look like the one you need?
Old 04-21-2012, 09:08 PM   #7
Scott26
Scott26's Avatar
ya it looks the same but all three vacuum ports are on one side on mine. i know one of them on mine is a vent. so maybe the one in the back is a vent to.
Old 04-22-2012, 04:19 PM   #8
beamn7
You know, after you pointed that out, you are right. (been awhile since I looked at mine) So I did some serious digging on this. 1997658 is the GM number for the Fed emissions or high altitude models.
Ours takes 1997657 which crosses over to a delco 214-327 which is discontinued but.........Autozone has part number EVS41 which is the exact part. For some reason, their catalogue is incorrect in the listing for yours as well as mine...... Imagine that, never seen that before! LOL ya right...
Here is a picture of the correct one:
Old 04-22-2012, 04:29 PM   #9
Scott26
Scott26's Avatar
your the man! how did you find that? ive been looking for that forever! thanks alot
Old 04-22-2012, 04:35 PM   #10
Scott26
Scott26's Avatar
how did you find that??
Old 04-22-2012, 04:43 PM   #11
beamn7
I use a couple different websites. Some give you the entire number, some part of the number and then of course google. Once I got the number I just google image search the number and a brief description like "egr 1997657". Here's some of the links I use that are helpful finding GM numbers:
http://parts.nalleygmc.com/
http://www.gmpartsdirect.com/
http://www.gmpartsgiant.com/
http://parts-catalog.acdelco.com/cat...log_search.php
http://www.gmpartswiki.com/
GM parts giant doesn't give the entire number but usually you can guess the first two. I'll start googling the number and guessing the first two until I come up with a good number and a photo match....
This works good for discontinued parts locating:
http://www.partsvoice.com/
Glad to help out a fellow square!
