Old 04-20-2012, 10:54 PM   #1
j1970GMC
CPP Trac Bar: Shim Neccesary for blocked truck?
Hi Everyone,
Im almost finished installing my CPP trac bar on my 67 C10. My truck is dropped in the back with blocks and already has a shim. Is it really necessary to use the provided shim for the left trac bar? It's starting to have too many layers....How much difference would it make to not use it? Thanks for any help.
Here is the link to the sway bar kit:
http://www.classicperform.com/Store/...ck/CP32021.htm
j1970GMC is offline   Reply With Quote
Old 04-21-2012, 11:44 AM   #2
j1970GMC
Re: CPP Trac Bar: Shim Neccesary for blocked truck?
I just talked to CPP. They feel that the shim is really needed. I guess I already knew that, but I was just hoping that a small shim didn't matter.
I'll put the other shim in today.
Old 04-21-2012, 11:23 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I would think by not using the shim and keeping the axle level in relation to each arm mount, you would end up putting a "twist" into the suspension and possibly causing some binding. Smart move to put the shim in as instructed.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-22-2012, 12:33 PM   #4
j1970GMC
Yeah, that's good advise. Putting in the shim was actually a lot easier than putting on the bracket on the right trailing arm. Looking back, it was kind of a stupid question. I was just hoping and being lazy, which never did anyone any good...
