power steering delete belt
anyone happen to know what belt i would need if i dont run a power steering pump on a 2006 LM7 ?
Re: power steering delete belt
How are you wanting to route the belt? Mine goes around the alternator under the water pump around idler on passenger side and under crank pulley. Works well. I'm running an f-body alternator with a 69 inch belt. If you run the truck alternator you will need a longer belt as this alternator sets higher. Hope this helps.
Posted via Mobile Device |
yes i think i will be running similiar to yours however with the truck mount similiar to this.. i measured around 70-71" with the adjuster loose (not compressed) so I may try about a 67" belt ?
