1 Wrench / 10 Knuckles
Installed 275r60-15 and have noticed the front end tends to wander. Nothing drastic but it tracked perfectly before with the 235's. What repairs or adjustments are required to correct this?
thanks
1970 GMC Custom Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers 2006 Dodge Charger SRT8. 1/4 mile 13.3 1973 Z1 900 Kawasaki ( all original) |
Bigger tires put more stress on everything. Assuming you have good ball joints, tire rond ends, idler arm, etc.; You may want to tighten up your steering box a little.
69 SWB LT1/4L60E www.classicplace.com |
![]() Join Date: Apr 2003
buckola,
Minibike is right, start with checking everything out, and then tighten your steering up. I had to do this on my 72 david
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
Might need to reset you camber with the wider tires and rims.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
Thanks for the advice guys. I suspect I'll have to tighten up the steering...dumb question number 2... how do I do that?
Steve ps You were right Griesal...they fit well and fill up the wheel well nicely. I'll post some pics tonite.
Just make sure everything is in good condition, A worn (a.k.a loose) suspension will allow the wheels to follow the path they want instead of the path your steering in.
Also, you will get alot of "darting" or wander with wider tires on the front. They will tend to follow the high spots on the road, which shift from side to side. You will notice it more when coming to a stop light where the ruts are deeper. You can adjust your gear box by loosening the locknut and rotating the adjuster stud clockwise. Do this with the front end off the ground and only turn the adjuster 1/4 turn at a time. Check for a tight spot or binding when the wheel returns to center. You'll want to take it to the point where its binding then back the adjuster 1/4 turn and tighten the locknut. If you feel binding while driving, rotate the adjuster counterclockwise, do not let it stay this tight. make sense? ![]() Last edited by Piston; 05-09-2003 at 10:09 AM. |
![]() Join Date: Jan 2000
Here is another thought on this...Are you using the same wheels with the bigger tires? If you are using the same width rims with wider tires, the wandering maybe the additional tire footprint sticking to the pavement while the tire sidewalls are flexing more because of the increased distance from the rim to the tread relative to the 235 that you used to have on the truck.
Thanks again guys....I'll check it out on the weekend.
It never seases to amaze me how soon you can get answers on the board...day or night!! Makes me wonder some times if anybody here works!! And if they do, how much company time do we spend on the company computers? Hmmmm....perhaps an interstesting question to post. thanks again Steve
Ive got 295/50's all the way around on mine. Mine tends to wander a little at higher speeds. Im gonna go smaller in front one of these days. My steering if tight though. No complaints here.
Guy
guypm 1971 SWB Fleetside/350 performer rpm heads &intake/ holley 750dp/1.5roller rockers/MSD6a/700r4 1650stall/one piece driveshaft/3.73 open/dynomax ceramic coated headers/3chamber flowmasters/ |
buckola
get those pics on for all of us to enjoy david
its all about the +6 inches
Stupid question...what are your tires inflated to? Most places will only fill your tires to 32PSI after installing them. They don't care if the tire is designed to run at 90 PSI.
