![]() Join Date: May 2009
Booster/Master cylinder for a '71
I have a 71 Cheyenne that came from the factory without power brakes. I'm looking for an assembled ready to "bolt on" booster/ master cylinder conversion set up to put power brakes on it. I want a factory look 11" cad plated booster and GM master cylinder. When parts need to be replaced, I want to be able to find the parts. A Delco Moraine stamp would be a plus.
There are a few offerings on ebay that are pre-assembled with hose, fittings, prop valve, etc. I haven't seen any with Delco Moraine stamp. Some conversion setups require relocating the the hole on the brake pedal, and some say that they do not require relocating hole. I would also need a firewall boot and bolts. I'm hoping someone can point me in the right direction. I've got a '71 and a '68 to do. Thanks, Eddie |
