Old 04-21-2012, 04:34 PM   #1
grs
Door glass was hard to roll up. ????
My passenger door glass was so hard to roll up I had to pull up on the glass to help it go up. I noticed that the glass was thicker then the drivers door glass. I bought a real good door glass at a salvage yard for $25.00. I installed it, and now it rolls up so easy. Do some trucks have thicker glass then others?
grs is offline   Reply With Quote
Old 04-22-2012, 10:02 AM   #2
xrcr
Re: Door glass was hard to roll up. ????
I was told the older is thicker than the newer. I only have 79 and older glass so I can't verify. My question is was your pass. window always hard from day one? I guess it don't matter if it's working now huh...
xrcr is offline   Reply With Quote
Old 04-22-2012, 10:19 AM   #3
grs
Someone replaced the passenger glass with a thicker glass. I now have a good thick glass that I can't use.
Old 04-22-2012, 01:32 PM   #4
cory d
cory d's Avatar
in 1981 these trucks dropped about 300 lbs with the new front clip and thinner glass
if i remember correctly
cory d is offline   Reply With Quote
Old 04-22-2012, 02:02 PM   #5
grs
I checked the LMC book, and there is a different number for 1973 to 1980, and 1981 to 1987 trucks. So the last owner put the wrong glass in it. Thanks
Old 04-22-2012, 02:21 PM   #6
cory d
cory d's Avatar
i have the same problem with my truck but i think one of the previous owners but 81+ tracks in it
Old 04-22-2012, 05:30 PM   #7
grs
Check the glass in each door, and see if one is thicker then the other.
