05-09-2003, 09:13 AM | #1 |
user # 2756
Brake proportioning valve
Is there a difference between the power assisted and non-power brake proportioning valve for a 70? Why I ask, the PO convereted the truck from manual to power brakes but the PV looks like it was not replaced.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-09-2003, 10:08 AM | #2 |
What does the valve look like? Proportioning valves are used with disc brakes as the flow between front and rear are different.
I would think that your valve is not a true proportioning valve but is set up to separate the front from the rear if there is a leak. It should work fine with the power brake booster. Jim |
05-09-2003, 10:13 AM | #3 |
user # 2756
So all it's there for is the idiot light, since I have front and rear drums.
Should be some pics in my signature link under drivetrain in the first row.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm Last edited by JIMs70GMC; 05-09-2003 at 10:17 AM. |
05-09-2003, 12:56 PM | #4 |
That is what the valve is, as you said!
I liked the "Truck in the snow" picture! Jim |
05-09-2003, 01:29 PM | #5 |
user # 2756
Thanks, I need to get some action pics though!
