Old 04-22-2012, 07:40 AM   #1
Spaz
Body panel repair
I have a few rust thru spots on my 71. I was noticing some of the pics of panels ive seen were just tack welded using mig. Isthe tack welding on body panels all u need or is it need to be completely welded? Just thought the tack welding was to keep from warping as the panel was welded. Any input? I wanna learn to do this as im looking to keep this truck for a lon time.
Spaz is offline   Reply With Quote
Old 04-22-2012, 09:06 AM   #2
El Campo
El Campo's Avatar
Re: Body panel repair
The problem with not welding it entirely is that years later your body filler shrinks into the cracks and they start to show through the paint. I had my handles shaved by a so called professional and they just tacked it. Sure enough, a few years later and they are all showing. Just go really slow and move around.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 04-22-2012, 09:27 AM   #3
hugger6933
Weld it up completely. The tack you may have seen might have been at the start or middle of the process. When I am welding a panel I do small tack and alternate points farthest away from each other. Dont get in a hurry take lots of timethe longer you take in this step will reduce time in the ones following it. I use a heat gun when I weld and take readings so that I know when it is time to stop for a Diet Coke break One of the many used for those little guns[ mainly used to take metal temp so I know when to paint]
hugger6933 is offline   Reply With Quote
Old 04-22-2012, 10:14 AM   #4
Spaz
Thanx for the info. I woulda never thought of the temp gun ideer.
Old 04-22-2012, 10:45 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
It takes about a bazillion tack welds all around the panel to weld it in. Like hugger siad, it needs to be done in alternating spots to keep heat from building and warping the panel.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
