CPP Trac Bar: Bushing Squeak?
Hi Everyone,
I noticed this morning that I have a slight squeak when I move the truck up and down coming from my newly installed CPP Trac Bar's bushings. Is a little noise normal? I'm kind of assuming that it isn't at that maybe I have to adjust something? Does anyone have any thoughts on that...? Thanks for any help. |
Re: CPP Trac Bar: Bushing Squeak?
Did you use the poly grease?
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
There is a special grease that you use with poly bushings it is very thick and very tacky that helps lubricate them, a little goes a long ways and it is not that expensive to buy a tube, should take care of that squeak...
