![]() Join Date: Apr 2010
2 piece drive shaft 67 c10 long bed
I need a 2 piece drive shaft for a 67 c10 long bed. Thanks. Wayne
![]() Join Date: Apr 2007
Re: 2 piece drive shaft 67 c10 long bed
I have one from a 69 c20 long bed. I think it should work depending on what transmission your running. This truck had a three speed manual and them sombody put a th350 in its place,same drive shaft for both. I also have a 67 c20 long bed with a 4 speed. Let me know which your running and do you have any measurements?
I am running a 700r4 so it is longer than the others. I will have to have one cut and the right end put on for a 700. I don't have any measurements because there is no carrier bearing mount in it. I am looking for one of those also. How much do you want for the drive shaft? I live outside Buffalo NY could you ship it? Thanks. Wayne
I had it posted with some other stuff,I had to go find it and look. $40 is what I had it listed for and you can have the hanger bracket with it. I'll try and figure out the shipping and get back to you this afternoon with the shipped price.
Thank you very much.
Something else that I thought of,Is your truck coil or leaf? this setup was from a coil spring truck.
Coil spring. Thanks
Ok I figure the shipping should be around $20 . I'll have to seperate the two halfs to box and ship.I assume you will be going with all new U joints anyway. Just for the record the hanger bracket comes with it but the rubber and the carrier bearing will need to be replaced also. Does the 700 use a diffrent yoke? if so I can knock the 350 one off and save on the weight and length of the package. Unless you want it it or need it, thats fine too. LMK
