Old 04-23-2012, 10:19 AM   #1
lucifer
lucifer's Avatar
wiper troubles??
Put the truck back together a while back and recently tried the wipers. They "park" in a vertical position instead of horizontal at the cowl. Anybody ever had this?
Does the switch control this?
Did I put something together backwards??
thanx in advance.
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 04-23-2012, 10:30 AM   #2
Jeff La
Re: wiper troubles??
How is the travel of the wipers? If the travel is to far you can let them stop and take the arms off and reposition in the right place.
Jeff La is offline   Reply With Quote
Old 04-23-2012, 10:32 AM   #3
lucifer
lucifer's Avatar
Travel is right they just park in the wrong position.
Old 04-23-2012, 11:21 AM   #4
1963c-10
1963c-10's Avatar
If its a two prong switch, you might have the plug reversed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-23-2012, 11:27 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Since the park mechanism is internal to the wiper motor gear/head portion of the wiper motor assembly, it sounds like either the wiper motor is mounted upside down (if this is even possible) or perhaps the wiring may be connected backwards.
Figures number 146 & 147 attached from the 1960 Chevy Shop Manual show the parking mechanism, and the text at the bottom of the first page and top of the second page explain the park feature functioning.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-23-2012, 01:50 PM   #6
lucifer
lucifer's Avatar
Thanks for the help. I will get it apart tonight.
Old 04-23-2012, 05:32 PM   #7
64fleetside
Your linkage is prolly 180 out. Unbolt from the motor, turn & re-connect.
64fleetside is offline   Reply With Quote
Old 04-23-2012, 05:36 PM   #8
cb1965
cb1965's Avatar
I had a similar issue. Turned out to be the linkage. Re arranged and problem solved
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 04-24-2012, 12:37 PM   #9
lucifer
lucifer's Avatar
Yup for sure the linkage was messed up. Little rearranging and they arok fine.
thanks to all
Old 04-24-2012, 03:28 PM   #10
kieth
kieth's Avatar
I referred to it as a timing issue, it was simple after scratching your head for a couple of hours.
kieth is offline   Reply With Quote
Old 04-24-2012, 03:51 PM   #11
lucifer
lucifer's Avatar
It was too simple for me to figure out. LOL
