Old 04-23-2012, 12:29 PM   #1
polock07
Polock07
1975 Front Axle under 1969 frame no Go?
i started to put a 1975 Dana 60 and Dana 44 under my 1969 c10 4x4 Frame, once under i realized i have to move the mounts, no big deal on back one just cut and re-weld, but front one passenger-side mounts the U bolts don't fit around the housing anyone out there have this issue and have a fix or should i start looking for a new front Axle?
polock07 is offline   Reply With Quote
Old 04-23-2012, 01:54 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 1975 Front Axle under 1969 frame no Go?
Different U-bolts? The U-bolt for the hosuing on the Dana 44 front has one bolt on the passenger side that is longer that wraps around the side of the housing. So you're saying you just need longer U-bolts?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-23-2012, 10:22 PM   #3
odog
odog's Avatar
I think you just need new u bolts. I have a 44 under my 69 and I am putting a HD dana 44 under it this week, (converting to 3/4 ton.) Anyway, the spring pad on the passenger side is part of the pumkin housing and you just need the u bolts for it. I wil try to get a pic
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 04-23-2012, 10:30 PM   #4
odog
odog's Avatar
Ok here are some pics of the spring pad. This a 44 out of a 76 3/4 ton. Name:  IMG_0660.jpg
The last pic shows the bottom of the axle tube next to the pumpkin that has the groove for the ubolt. the 1st pic is the pad looking down from the top. the 2nd and 3rd have the u bolt in place. Hope this helps
Erik
1969 4x4
Old 04-23-2012, 10:58 PM   #5
polock07
Polock07
the leaf spring seamed to be closer on the 69 frame so i moved the mounts on the axles to match, but the pumkin housing and bolts are in the way, i put a groove into the pumkin housing to support the new location and then noticed that two bolts on the cover where going to be in the way of the u bolts, from the first photo you can see that the bigger u bolt goes about half way into the two bolts on the cover, so i'am at a loss
Old 04-23-2012, 11:39 PM   #6
odog
odog's Avatar
I will try to figure out something tommorrow afternoon. Its too dark now to see anything.
1969 4x4
Old 05-02-2012, 04:41 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
The 1/2 ton (6 Lug) D44 and the 3/4 ton (8 lug) D44 were supposed to use the same axle assembly. It's just the hub, rotor and spindle thats different. There are spindles that use a small or larger bearing. Not sure what year that changed...
Rich
1972 K5 Blazer CST Click HERE
Old 05-02-2012, 10:57 AM   #8
mknittle
mknittle's Avatar
Yeap bigger axle housings need bigger U bolts most of the time. Anyhow it is a good idea to use new ones. And use never seze on them for lube.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
