Old 05-09-2003, 02:36 PM   #1
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
ID this rear end, please?
I just got me this week a '68 chevy 3/4 ton long stepbed, inline 6 with 3 on the tree, and this rear end is under it, I know is a 10 bolt but what ratio is the most likely to be?
Thank you for any help. Fatman.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 05-09-2003, 02:36 PM   #2
chevy_fatman
Where's my beer?
here's a close up.
Paul
Old 05-09-2003, 02:46 PM   #3
Rod
Thats the corporation diff / aka Eaton diff... in a 68 with a 6 cyl and a three speed I'd bet money on 457 ratio.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-09-2003, 03:11 PM   #4
chevy_fatman
Where's my beer?
Thank for the quick reply Rod.
If so, how highway friendly is it?
Thanks. Fatman.
Paul
Old 05-09-2003, 03:26 PM   #5
Rod
Its a pulling rear end.. not real highway friendly... 60 mph is pushing it... that 6cyl will be reving big time. But it is simple to put a set of 4.10 in... you can do it without even lifting the truck..., drain oil, pull the axles, disconnect drive shaft, take out the ten bolts at the forward part of rear of the diff...swap in the whole pumpkin from a 410 ratio...
reconnect drive shaft, slide axles back in, refill oil. Simple.
Old 05-09-2003, 03:35 PM   #6
chevy_fatman
Where's my beer?
Cool man!, so much aknowledge, it dwarfs me, all this info is greatly appreciated. Paul.
Paul
Old 05-09-2003, 03:38 PM   #7
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
yep. and FYI the only lower gear set i know of for those toys is a 3.90, so not much help there. If you're lucky it might have a locker unit (or posi i cant recall) in it. 4.57 would definately be my guess as well though. Good luck
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 05-09-2003, 08:49 PM   #8
Rod
You can buy 4.10 or 3.90 still today if you want.... they only want $995 for the complete pumpkin... or $460 for the gears alone.... go ahead and buy them if you wish... but you might wanna talk to somebody and get a second price.. I have a few sets of 4.10.
http://www.rearman.com/truck.htm
Old 05-09-2003, 10:34 PM   #9
jostrans68
Jostrans68
jostrans68's Avatar
Rod I got the gears for 225 at randys ring and pinion
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 05-09-2003, 11:36 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Rod, any chance you micht wanna part with a 4.10 set up? I don't think my caddy motor will like the 4.56 in mine.
