Old 04-23-2012, 07:26 PM   #1
72 Madness
shift linkage question
Ok guys, I have a 72 blazer. I am having trouble with the shift rod were it mets up at the column. It goes down though all of the gears fine however, when I try to pull it back up into park, the rod slips down and does not come all the way back up into park. I tightend the bolt up on the back side and it is still slipping. Any thoughts?
72 Madness is offline   Reply With Quote
Old 04-24-2012, 10:09 PM   #2
72 Madness
Re: shift linkage question
Sorry don't know how to take this post off. I figured it out.
Old 04-27-2012, 11:38 PM   #3
Scrat
Scrat's Avatar
No need to remove the post but maybe post the solution to the problem to help someone else down the road maybe =-)
Scrat is offline   Reply With Quote
Old 04-29-2012, 01:20 AM   #4
72 Madness
No problem. I didn't have the gap washer? lined up correctly. The one that tightens up to the shaft was turned around backwards. It wasn't not getting tight up against the shaft. I know that seems very simple but after working on this thing all day I start to go a little crazy sometimes.
