![]() Join Date: Jan 2012
35 in tires
will 35 in tires fit on a 1 ton with a 4 in lift kit
Re: 35 in tires
What year of 1-ton. I have 35" tires on my 85 3/4ton burb and it has a 4" lift.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Re: 35 in tires
on a 73-80 body style the fenderwells are slightly smaller then on an 81-87. 4" and 35s is common on a square headlight truck, but on a round head light truck it may be tight. some clear some wont, also depends on what brand lift you run. Some lifts run higher some run lower. Every truck sits different. Girlfriend has a 76 chevy 3/4 4x4 with a 6" superlift on it and she's running a 315/75/16 which is close to a 35 and it gets close to the rear of the front fender with the wheels fully turned. Hope this answers your Q
1984 Chevy K20 work in progress 1977 Chevy C30 Dump 1979 GMC 35 4x4 Dump 1969 GMC 1500 Rat |
