Trac Bar Alignment?
Hi Everyone,
So I'm trying to get my CPP Trac bar aligned properly (rear axle centered). The axle doesn't want to come over to make the distances even. I have play if I push it the other way, but it's tight where I have it now and it still needs to come over a about a quarter or half inch. I don't think I can get it over anymore (I've tried like 10 times). Is there a trick to this that I need to know about? Could something else be causing the alignment to be off? I'm measuring the distance between the frame and the rear tire on both sides to get my center measurement. I mocked up the stock panhard bar and it seems to fit right where it is with the alignment off???? Any thoughts would be appreciated. |
Re: Trac Bar Alignment?
I found this thread...
http://67-72chevytrucks.com/vboard/s...ad.php?t=74624 Could this be the problem. Have other people heard of sagging springs making it stick out to the passenger side? That is the side with too much room... |
![]() Join Date: Jul 2010
Try loosening the U-bolts that hold the axle to the trailing arm, then loosen the two front trailing arm mounting bolts (front of the arm -to-the chassis mount). With these bolts loose, adjust the panhard rod, then, with the truck sitting at ride hieght, tighten all of the bolts back to factory spec.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#4 | |
#5 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
For a quarter or half an inch, I always just hook a ratchet strap to the frame and across to the axle. Crank it to pull it in line, insert bolt.
