Old 04-23-2012, 11:36 PM   #1
chevymadness
Spring susp lift how high?
I have a 82 half ton and i want to level it out preferably 2 1/2 half.I just want the truck to have a good stance so i could buy some 35 inch tires with some big rims to give it some height.I dont know what coil spring to get or leaf springs and u joints etc.???????
1982 chevy silverado
It's all about original guys original let me say again original.
chevymadness is offline   Reply With Quote
Old 04-23-2012, 11:44 PM   #2
Shane22696
Shane22696's Avatar
Re: Spring susp lift how high?
Wait, is your truck 2wd?
80 K10 350 4 spd
4 Inch lift, 33 inch BFG M/t
Shane22696 is offline   Reply With Quote
Old 04-24-2012, 12:06 AM   #3
makman1297
makman1297's Avatar
Check this link out, pretty good job. You can use 88-98 lift spindles with 3/4 ton springs for a 73-87. In the rear you can use lift blocks or get some rear leaf brackets for a 4wd (LMC sells them) dont know if you will clear 35's or not. http://67-72chevytrucks.com/vboard/s...d.php?t=447061
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
Old 04-24-2012, 05:48 PM   #4
ymerej71
ymerej71's Avatar
I would say minimum of 4" lift to clear 35" tires... and that all depends on how wide of wheels / tires you're going to run as to whether your front tires will rub inside the fenderwells. Really, 5-6" lift would be ideal... That would give you plenty of lift to keep everything proportional to the tires.
ymerej71 is offline   Reply With Quote
