Old 04-24-2012, 07:40 AM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
I Need a front sway-bar
Anyone in the Charlotte area have an old front sway bar for sale?? Preferably cheap..... I'll pay shipping if I can afford it.
TobyArnot is offline   Reply With Quote
Old 04-24-2012, 10:38 AM   #2
southern parts
southern parts's Avatar
Re: I Need a front sway-bar
check the pull-a-part in charlotte. the swaybar`s the same up to about 78-79
southern parts is offline   Reply With Quote
Old 04-24-2012, 11:20 AM   #3
Classic Bowties
Always on the hunt...
If you end up with the 1-1/16" bar and want to replace the bushings and bushing brackets, I have a few of the below pictured bushings and clamps setups available in OE GM for $50. per 8 pc. set plus $6.10 for sending in a small USPS priority flat rate box. Mel
Classic Bowties is offline   Reply With Quote
Old 04-24-2012, 01:14 PM   #4
TobyArnot
TobyArnot's Avatar
I'll keep that in mind, if I can locate a sway bar....
Old 04-24-2012, 09:35 PM   #5
Last_Paladin
I have a CPP 1.25" sway bar, with brackets, poly bushings and links. I wish I had known, I have a friend driving to Myrtle Beach right now.
Last_Paladin is offline   Reply With Quote
Old 04-25-2012, 12:57 AM   #6
c1069
c1069's Avatar
I have one
Pancho
69 c/10 step side 454/400 with 3.07
c1069 is offline   Reply With Quote
Old 04-25-2012, 07:00 AM   #7
TobyArnot
TobyArnot's Avatar
How $$$ would shipping be?? I don't have a clue. I hope I can find one close, but many thanks.
P.S. L_P, I would have driven to the Beach to 'retrieve".
Thanks guys,
Old 04-26-2012, 07:08 AM   #8
TobyArnot
TobyArnot's Avatar
ttt
Old 04-26-2012, 10:19 AM   #9
southern parts
i have one. $50 plus shipping. includes frame brackets and bushing brackets.
shipping will probibly be around $30
Old 04-26-2012, 07:56 PM   #10
c1069
c1069's Avatar
mine is just the bar no brackets. 20 plus
Pancho
Old 04-27-2012, 10:03 PM   #11
TobyArnot
TobyArnot's Avatar
C1069 - PM sent.
Southern Parts - Thanks for the offer.
Old 04-29-2012, 12:04 PM   #12
mytruck70
i got 1 but im in the Raleigh part of NC i would charg 40$ if you came and picked up
mytruck70 is offline   Reply With Quote
Old 05-03-2012, 02:28 PM   #13
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Have a new pair of poly/graphite bushings for $20 plus the ride, 1-1/16"
Hard Luck is offline   Reply With Quote
Old 05-04-2012, 10:11 AM   #14
TobyArnot
TobyArnot's Avatar
I think I have found one (Craigslist) in Waxhaw, NC, about 15 miles away. Thanks to all. I just knew somebody from around here had one. A C20, big bar, to boot.
Old 05-04-2012, 10:16 AM   #15
29od1
FYI incase someone told you different.
C20 sway bars are the same as the C10. Only 67 had a 1" sway bar and 68-72 were 1-1/16".
The 73+ 2wd sway bars are 1-1/4".
29od1 is offline   Reply With Quote
Old 05-04-2012, 10:28 AM   #16
TobyArnot
TobyArnot's Avatar
I stand corrected. I will be glad to get any size. Way better than none. Again, Thanks to all.... Plus, It's close and cheap, my two favorite things.
Old 05-04-2012, 10:35 AM   #17
29od1
I agree, any sway bar will help out a lot. I just didn't want someone trying to get you to pay more by misleading you.
